D90 will not start possible ecu or wiring? - Page 2 - Defender Source
Old December 19th, 2014, 05:40 PM
richpmnelson
Rich
95' Land rover d90
Originally Posted by aka rover View Post
FYI both of the 95s in the shop are white wires black strip .
Attachment 108955
that wire is coil to ecu wire please refer to http://www.g33.co.uk/images/PDFS/14c..._injection.pdf page 1 wirring diagram. the MAFS is Blue w/ Red stripe.
------ Follow up post added December 19th, 2014 02:45 PM ------
Originally Posted by ezzzzzzz View Post
Disconnect battery - . Pull the connector free of the ECU. Reconnect battery -. Check for 12v at pin 16 of the ECU. If it's not there your problem is between the battery+ and ignition switch. If there then turn key to run. Check for 12v at pin 19. If not there but is at pin 16 you've got a bad ignition switch or local wiring problem. If you're not getting a check engine light (even with the ECU swap) you're probably not getting 12v through the ignition switch. That also allows the fuel pump relay to kick in. You're looking well beyond the trouble area.
both 16 & 19 show 12 volts with ignition in the on postion, also i have already bypassed the ignition switch.
Old December 20th, 2014, 05:15 AM
aka rover's Avatar
aka rover
ed angel
95 D90
You are correct on the wire color .
85 D110 3.5 3 DR
Old December 20th, 2014, 09:16 AM
richpmnelson
Rich
95' Land rover d90
Attachment 108996
is this pic from an online recource, or a hard copy you have?
Old December 20th, 2014, 09:44 AM
Use some of these and save them as favorites to your smartphone or PC or MAC. 14CUX PDF and workshop manual.
http://landroverforums.com/forum/att...stems-info.pdf
http://www.internet-tools.co.uk/land...l%20(1993).pdf
Old December 20th, 2014, 09:47 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
It's from this article…
http://www.britishv8.org/articles/rover-14cux-efi.htm
Old December 20th, 2014, 03:02 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Great site for conversion info.
85 D110 3.5 3 DR
Old December 23rd, 2014, 01:01 PM
richpmnelson
Rich
95' Land rover d90
ok i'm at the end of my rope, all signs point to the ecu but there is no way i have 2 bad ecu's, just finished cleaning and ensureing all grounds are solid, checked all fuses and conections at the coil. ecu is getting power where it needs it. but still no check engine light or power to pump relay, and yes pump and relay are in working condition. what is wrong with this thing?
Old December 23rd, 2014, 05:30 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
if you hot wire fuel pump can you hear it run....... connect 87, 87 and 30 0n the pig tail....
the 30 is live all the time... do you have power?
If so then go down to next connection below gas fill do you have power? if so then its the pump or connection...
sorry if you already did this,,,,
pm a number and we can talk,,,,
good luck with your search
Old December 23rd, 2014, 08:45 PM
Rollover switch?
Old December 23rd, 2014, 09:33 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
X2 on the rollover switch
Old December 23rd, 2014, 10:50 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I used to carry a jumper to rule out the rollover switch when my NAS wouldn't start. With the plug being on the bottom of the switch and the plastic now 20+ years old it doesn't take much to vibrate them apart. I finally zip tied the clip closed to make sure it would stay on.
Not to mention It could be tripped or even bad.
Old December 24th, 2014, 12:11 AM
richpmnelson
Rich
95' Land rover d90
Rollover switch?
are you talkimg about the inertia switch. if so, it is fine the pump gets power if i hot wire at the relay.
Old December 24th, 2014, 08:44 AM
Are the wires in the back of the alternator secure?
Do you have spark at the plugs? You mention you have it at the coil but is it reaching the plug?
Old December 24th, 2014, 09:09 AM
carlosz's Avatar
carlosz
Carlos
There is a fuse to those relays, if ok then do a wire wiggle test behind the fuse box..those connectors fail due to corrosion or poor contact.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old December 24th, 2014, 09:33 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Does your '95 have an alarm or immobilizer?
Originally Posted by Roverlab View Post
Here's where it gets interesting:
The last wire is orange/light green going to alarm unit. Reading through the RAVE, there is reference to the alarm unit having some effect on the Check Engine light as part of it's function to Immobilise the car from starting ie: the CEL wont illuminate if the Immobiliser is in effect.
From this thread but it's talking about a '97… http://www.defendersource.com/forum/...k+engine+light
Old December 24th, 2014, 10:58 AM
richpmnelson
Rich
95' Land rover d90
i dont think, so ive checked for the immoblizer but they only come in later models. also im getting no check engine light what so ever.
Old December 24th, 2014, 11:02 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Silly thought… could it just be a burnt out CEL bulb causing the problem??
Old December 24th, 2014, 11:03 AM
richpmnelson
Rich
95' Land rover d90
i have yet to check spark at the plugs but im more worried about he fact that the ecu is not sending power to the pump relay.
Old December 24th, 2014, 11:09 AM
Does the relay not power up for a second or so with the ignition? If that's not happening it's likely a fuse.
If you hear the sound of hooves think horses not zebras.
Old December 24th, 2014, 11:16 AM
richpmnelson
Rich
95' Land rover d90
hmm.. ill have to check that ive already got the dash apart, but it shouldnt effect anything it the end of the line comming from the ecu.
90, d90, ecu, start, wiring
2 4.2 ECU's 1 3.9 ECU eliaschristeas For Sale - Parts 3 June 19th, 2013 03:15 PM
Start no start leastonce Defender Technical Discussions 10 February 25th, 2012 02:33 PM
no start... ECU? MikeRuby Defender Technical Discussions 18 August 3rd, 2010 06:36 PM
Need an ECU... looking for the ECU out of a 95 Disco or equivalent IPSC_GUY Wanted 7 February 16th, 2010 04:36 PM
» Defender Registry
mannarosa
motard
248
xjahx
Add your Defender
