D90 Temp gauge: Range? - Defender Source
Old September 4th, 2015, 02:49 PM
gilby's Avatar
gilby
1994 Defender 90
Might anyone know what the temperature sweep is on the stock temp gauge? '94 D90.
Mine will get into red, but an IR thermometer reads only 200F at the sending unit.
G
Old September 4th, 2015, 03:47 PM
G
Might be a bad ground ... there are 3 wires on the gauge ...
ground .. jump this direct to your battery -ve.
12V ... jump this direct to your battery +ve
and the sensor ... run a replacement /temp wire
that way you can replace the wires one at a time and figure whats causing the excessive sweep. If it still does it then the gauge of sensor are faulty. Sensor can be tested with a multi meter for resistance. Gauge I'm not sure.
Many people move to VDO at this point!
Old September 4th, 2015, 03:51 PM
gilby's Avatar
gilby
1994 Defender 90
Thanks.
The sensor is new, so I'm assuming bad gauge.
I can't imagine the stock gauge reads red at 200F
Old September 4th, 2015, 04:02 PM
Is the behavior the same for pre and post new sensor?
If this happened when you put the sensor in, it could be the range on the sensor is wrong and doesn't match the gauge.
Old September 4th, 2015, 05:46 PM
gilby's Avatar
gilby
1994 Defender 90
Was having issues before the new sensor, but not as dramatic as after the sensor. I would never peg red before the new sensor; just about 3/4.
Old September 4th, 2015, 06:26 PM
Sounds like you don't have the right sensor. 200 degrees should be just past center. I'd take the opportunity to switch to a VDO gauge with matching sensor so you see the actual temps
Originally Posted by pendy
I'm here for the D's
Old September 5th, 2015, 09:34 AM
gilby's Avatar
gilby
1994 Defender 90
Thanks for your thoughts, Jason and Charles.
D90 Temp Gauge 94/95 Jon_Winningham Wanted 0 December 14th, 2006 10:21 AM
WTB: 94/95 D90 Temp Gauge newfD90 Wanted 12 August 17th, 2006 11:03 PM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
temp gauge ron Wanted 0 December 10th, 2003 12:44 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
