D90 storage - Defender Source
Old January 8th, 2004, 12:09 AM
sonnyr
Sonny Reagan
Question D90 storage
I must store my 95 D90 SW for 18 months while on military deployment. I have a garage at my home and I live in the Southeast. How should I focus my attention in my effort to prepare the Defender for storage? Thanks,
Sonny
Old January 8th, 2004, 12:26 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Apart from the usual, I'd probably jack up the frame so the springs can relax the whole time. Might want to wipe some rubber conditioner on all the rubber as well.
More caution could be applied when you first run it after returning I might imagine. You might arrange for a friend to stop by once a month and run the engine. Otherwise disconnecting the battery might be in order but there may be side effects of that.
Old January 8th, 2004, 12:44 AM
yeah i think sit the frame on jackstands. people always tell me its better to keep your gas tank full or moisture will collect? i would disconnect the batt. I bet there are some fuel system additives for storing.
Old January 8th, 2004, 09:00 AM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
I could "take care" of it for you for 18 months and I wouldn't even charge you!
Kidding aside, I see a product all the time on those infomercials called "stabil". I think it stabilizes the oil in your engine. Haven't used the product ever but, hopefully someone can comment about it. I'm sure there are other products out there.
As far as your military deployment, BE SAFE and thanks!
Glenn
Old January 8th, 2004, 01:46 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Sonny, key is the gas and engine areas. Disconnect battery. In 18 months, there will be breakdown of the gas. I do not recall if an empty or full tank is better, but additives are a must. Good place for advise - if there is a boating store near by ask them. They store boats in the off season (opps, l I see you are in Alabama so thats dumb advise). Yoh, any NE input?
I'm contemplating thinking about thinking about it!
Old January 8th, 2004, 02:02 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
As I do with a boat for winter storage this would be good to do with any car stored for a period of time. Change the oil, fill the tank and put Stabil in it. Buy a can of engine-stor from any boat store. You spray it into the air intake while it is running and it coats the cylinder wals with an oil to help prevent condinsation and rust on the cyl walls. When you go to start it after a few months it just smokes a bit for about 5 min. till it burns the oil out.
Legend in My Own Mind.
Old January 8th, 2004, 03:22 PM
wicks's Avatar
wicks
Wicks
Follow Randy's advice there, that's great.
And yes, full tank is right. I think Rover engines detuned as such can pretty much burn anything that will explode under pressure, but err towards caution.
Old January 8th, 2004, 07:40 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have been doing that winterizing for years on my boat which has twin Merc 420's which are a 420hp version of the 454.. I never had a problem. Start right up every spring.
Old January 8th, 2004, 09:39 PM
back to the stuff you spray in the intake would you have to by pass the MAF? i have heard bad things about when the oil from K&N's get on them????
Old January 9th, 2004, 08:02 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yes, spray it directly into the intake so not to fowl the sensor..
I hope this all helps.
90, d90
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Storage Boxes chrisvonc For Sale - Parts 8 January 27th, 2005 02:19 PM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
D90 Car Cover with Storage Bag Erik For Sale - Parts 3 September 21st, 2004 12:51 PM
