D90 Step Rails & Rusty Bolts - Page 2 - Defender Source
Old January 25th, 2012, 09:45 AM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
In my case it is also where the rock sliders mount. Beyond the fact that it is a primary connection between the bulkhead and chassis, I want a solid mounting point that is not going to bend or sheer in the event that it takes a hit.
Old February 2nd, 2012, 08:04 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
I cleaned up one of the old bolts, it says it's grade 10.9 which has a tensile strength of 1040 MPa. The stainless ones are 101,000 psi which is 696 MPa. So the stainless bolt will be approximately 2/3 as strong (in tension anyway).
90, bolts, d90
D90 Running Board Plastic Side Step Cover & 4.0 Plenum BMGmotors For Sale - Parts 3 April 15th, 2011 12:27 PM
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
D90 rear step bumper on an '83 110 BEIS Defender Technical Discussions 0 November 26th, 2008 01:02 PM
!&*@! ..... still overheating! jaherring Defender Technical Discussions 63 July 13th, 2006 05:42 PM
