D90 starts then stops - Defender Source
Old September 21st, 2014, 09:58 PM
Hinckley423's Avatar
Hinckley423
Charles Joerss
1995 D-90 #2812
I've got a 1995 D90 ST. The other day I took it out and it started just fine. When I parked it and turned it off, I decided to move the truck up a few inches. I went to start it and it would start then quickly die, almost like it wasn't getting enough fuel. After letting the truck sit for about 1.5 hours, I went back and tried again. It did the same thing but on about the fourth try, I started and ran fine. About a week before this, the truck wouldn't start at all. It was on a battery tender and cranked just fine but wouldn't start. I don't know if that's relevant to this.
Has anything like this happened to anyone here before? Any advice would be greatly appreciated. I searched the threads and found some stuff but nothing like this situation.
Thanks again,
Charles
Old September 21st, 2014, 09:59 PM
Air idle control valve.
Old September 21st, 2014, 10:45 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Yup.
Old September 22nd, 2014, 02:58 PM
Hinckley423
Charles Joerss
1995 D-90 #2812
Thanks. I'll take a look. I appreciate the advice
90, d90, start, top
Clutch pedal sticks to floor, then starts popping up as the truck gets warmer. Quimbola Defender Technical Discussions 7 December 30th, 2008 04:43 PM
surprised at 300Tdi cold weather starts Gkase Misc. Chit-Chat 6 December 6th, 2006 09:11 AM
D90. Runs then dies, and hesitates intermittently. ScottYates Defender Technical Discussions 6 November 15th, 2006 07:01 PM
D90 Starts Slowly. Any ideas? cdnpaul Defender Technical Discussions 7 October 31st, 2003 11:27 PM
