D90 stalling/soaring idle - Defender Source
Old June 16th, 2010, 09:48 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Cool D90 stalling/soaring idle
D90 is stalling after engine rev/slow down, and sometimes soaring idle. Is it the little solenoid thing screwed into the intake?
Old June 17th, 2010, 12:19 AM
Probably. It is the stepper motor or, in american, the idle air control valve. I believe on a 1997 it is the same as a disco I but don't quote me.
Old June 17th, 2010, 12:46 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Yes it is the same as a Disco. There is a NAPA cross but I can't find it right now. Try removing it and cleaning it with carb/brake cleaner 1st. Worst case you will have to visit a dealer (or somebody with access to a Rovacom/Autologic, etc.) and have the base idle re-set.
Old June 17th, 2010, 12:51 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
STP makes some great intake cleaner that will disolve the carbon build up. As worked for me on several occasions.
Old June 17th, 2010, 02:27 PM
wicks's Avatar
wicks
Wicks
I have cleaned it and flipped it over numerous times, i think there is something wrong now. Where is best to order that online?
Old June 18th, 2010, 12:27 AM
61rover's Avatar
61rover
John Crouse
I've had no issues with the Chevy Astro equivalent.
Old June 18th, 2010, 03:49 PM
wicks's Avatar
wicks
Wicks
Wow, cool. Anybody got a link to order?
Old June 18th, 2010, 03:52 PM
http://www.defendersource.com/forum/...74&postcount=3
No experience with this part.
Old June 18th, 2010, 07:55 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Thanks Ron. Couldn't find the part # when I looked the other day. Only diff between the 2 is the AC part is gold colored and the LR is black. AC part is a LOT cheaper.
Be prepared for the possibility that replacing the IAV alone may not cure the problem if the ECU has lost touch. The ECU has a 'learned' range for the plunger and sometimes if there is a sudden change (Cleaning, fault, replacement, etc.) then it will spend all its time over and under correcting itself and your idle will vary from stalling and almost nothing to 2 or 3k. Fix is to take it to somebody with a LR diagnostic computer and have them reset the ECU and the base idle setting.
Originally Posted by evilfij View Post
Old September 8th, 2010, 04:10 PM
wicks's Avatar
wicks
Wicks
Still haven't been able to find the stepper part. Anyone know a part number or link to order?
Old October 17th, 2010, 04:56 PM
Haroldf747
Harold Frear
1997 D-90 Soft Top
Just put one on my 97 a few weeks ago. Advanced Auto Parts Borg Warner #21774 - Idle Air Control Valve $43.19+tax. However it didn't fix my problem of stalling as I come to a stop.
90, d90, idle
High Idle on 97 D90 ndhlp Defender Technical Discussions 3 November 26th, 2006 11:59 AM
1994 D90 Idle "hunts" TonyV Defender Technical Discussions 3 June 1st, 2005 04:47 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
d90 bogging & hesitating off idle vesparover Defender Technical Discussions 11 April 9th, 2004 04:03 PM
