D90 squeak over bumps. Front driver suspension? - Defender Source
Old May 11th, 2016, 07:39 PM
jec
Jay
1997 D90
I have a squeaking noise that sounds when I go over a bump on road. It doesn't always happen but recently has started to happen a lot. It's driving me crazy trying to identify what it is. It sounds like a suspension but I'm a layman mechanic. I open my window and listen as I'm driving. Is something in need of oil.
Welcome any thoughts. Definitely want to diagnose the issue and correct it. Appreciate any thoughts in advance.
Better lucky than good.
Old May 11th, 2016, 08:34 PM
richord
Richard Ordowich
1987/D90
It could be the rubber bushings on the shock absorbers. They dry out and begin sequeeking. Replacement is the only fix. Mine was suffering with this annoying sequeeking and stopped when I replaced the shocks.
"Slow down and smell the diesel"
Old May 11th, 2016, 08:44 PM
jec
Jay
1997 D90
Great. Thank you. Any rough idea of cost to replace?
Old May 12th, 2016, 05:59 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
The parts are nothing. Bushings for the shocks are probably 20-30 bucks but guessing by the layman mechanic comment you're taking it to a shop which would be the biggest cost. For me, pulling the front shocks is one of the bigger pain in the ass jobs i hate doing. Before you dive in, have someone jump on the bumper while it's parked and see if you can trace the noise while you're underneath. If you find it, spray with WD40 and see if that stops it for 10 seconds. Least then you'll know for sure what you have to change.
Old May 13th, 2016, 08:23 AM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Check the hood hinges... If it's the culprit, shake the hood with your hands in every direction and you should hear it chirping.
I'm for the Russian pencil
Old May 13th, 2016, 03:38 PM
carlosz's Avatar
carlosz
Carlos
if you have sway bars, check the links. they have a ball joint which dries and thus squeak . they should be nice and tight with out play and clean dust boots in one piece
Old August 5th, 2016, 08:47 PM
jec
Jay
1997 D90
Thanks to all. Appreciate the tips.
90, d90
Bumps on NAS 90 (SW) Roll Cage Manimal Defender Technical Discussions 1 July 3rd, 2013 06:02 PM
rear bumps stops and rear spring seat jjstahl3 Wanted 0 January 18th, 2012 12:51 PM
Front wheel squeak bjf Defender Technical Discussions 15 December 6th, 2010 03:53 PM
Shutoff Squeak Jon_Winningham Defender Technical Discussions 1 January 23rd, 2007 03:46 PM
Wicked Squeak ronward Defender Technical Discussions 1 July 16th, 2004 03:39 PM
