D90 springs on a discovery - Defender Source
Old April 16th, 2010, 06:39 PM
easy's Avatar
easy
Dan Duncan
White '94 Disco 1
Ok, I tried the search but didn't come up with anything. I was wondering how stock D90 springs compare with Disco I springs? Are they taller? Exactly the same? I have some stock D90 springs and was thinking about throwing them under the Disco but if they are exactly the same this would not make sense. Anybody have any info for me? If not could you point me in the right direction?
Old April 16th, 2010, 08:19 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have a pair of 90 springs if you are looking
Legend in My Own Mind.
Old April 16th, 2010, 08:34 PM
Slightly taller, especially the fronts.
Old April 21st, 2010, 04:47 PM
easy's Avatar
easy
Dan Duncan
White '94 Disco 1
Thanks Randy but I have some left over stock D90 springs already and am just wondering if I could throw them under my dads Disco. Does anyone have any exact specs on Disco springs?
Old April 21st, 2010, 05:53 PM
The rears will cause a drop and the fronts a lift. Not a good idea.
http://members.shaw.ca/jbarge/springinfo.html
Tell me what you want to achieve, and I can make a suggestion.
Old April 22nd, 2010, 08:08 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
cool site John..
Old April 22nd, 2010, 01:38 PM
easy's Avatar
easy
Dan Duncan
White '94 Disco 1
Good site, thanks. I would WANT a 2-3 inch lift on the disco, would any of my D90 springs do this? If my D90 springs would give it only a slight lift, that would be better than it is now. I was just wondering if I could lift the disco without buying new springs. BTW its a 94 Disco
Old April 22nd, 2010, 01:52 PM
You can put in genuine springs in the front to get that kind of lift, but you need aftermarket springs to lift the rear.
Old May 4th, 2010, 02:28 PM
easy's Avatar
easy
Dan Duncan
White '94 Disco 1
Thanks John, so are you saying that if I swapped out the fronts that would give me about 2"? This would be nice, then I might just put some spacers in the rear. I MAY be inheriting the Disco from my dad and I don't want to spend much if any money at this point so I'm just mulling this idea around in my head right now.
Old May 4th, 2010, 02:33 PM
Buy OME HD or MD rears and put stock rear springs in the front. BTW what is on my D90 is not what is on that chart.
Old May 5th, 2010, 12:20 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Originally Posted by easy View Post
Good site, thanks. I would WANT a 2-3 inch lift on the disco... BTW its a 94 Disco
I ran OME 764's in the front and 759's in the rear of my '96 Discovery. These gave me about 3" of lift, and I ran 235/85-16 tires. I thought it was the perfect combination ( I was also running Fox/SG Stage II shocks with it), the truck drove great, still rode well, and I didn't experience the Castor issues I did with my lifted 90. The 759's are not available anymore (unfortunately, but I think Rovertym made a duplicate of it because of demand)), but the 764's are. Now keep in mind I had an ARB winch bumper and an X9 hanging on the front, if you don't, the 764 may be too much spring for what you want to do..
~Scott T.
'95 D-90 ST - AA Yellow
Old May 5th, 2010, 02:29 PM
easy's Avatar
easy
Dan Duncan
White '94 Disco 1
Beautiful disco Scott! Thanks for the info, i'm glad to hear that you didn't have the same issues with castor, I was worried about that. Ron, do you mean put the stock Disco rears on the front? Do you have a guess as to how much of a lift that would give me?
Old May 5th, 2010, 03:31 PM
Yes stock disco or D90 rears on the front will give you 2in or so on an unladen truck. Search Cheap Bastard lift on dweb.
Old May 5th, 2010, 04:23 PM
On a related note, what are my best (read cheap) options for lowering a truck short of cutting down some springs? Specifically I have a D90 frame/suspension on my trailer and I want to lower it a few inches.
Old May 5th, 2010, 04:30 PM
What springs do you have ATM? What is the compressed length? Do you want lighter or stiffer?
Old May 5th, 2010, 04:34 PM
John, they are from a early defender afaik. I don't know the compressed length offhand but part of the issue is that the trailer is light so they don't compress much. The trailer really doesn't need much travel and it's super slinky right now so I guess stiffer would be fine if shorter but I guess lighter would compress more? But the key is I want to go lower and keep everything else the same suspension wise. And it needs to be cheap or I'll just keep it as-is or cut some down and see how those work out.
Old May 5th, 2010, 04:38 PM
Are they front or rear springs? Measure the compressed length and I can see if anything would work. Not sure how cutting would work. The stock springs have closed and ground ends.
Old May 5th, 2010, 04:47 PM
No idea what they are because they were old/junk ones i got from Ren Ching's house o parts. They are rusty with no discernible markings. They were roughly the same height uncompressed but compressed one is about 13 1/4" the other about 12 1/2". I have another pair so one day when I am feeling energetic I'll play swap the springs and measure them compressed in different combinations.
If I cut them I figured I would put the cut end down and hold in place with a retainer, but no idea if it will work
Old May 5th, 2010, 04:52 PM
easy's Avatar
easy
Dan Duncan
White '94 Disco 1
Awesome, thanks. It looks like Discoweb is down for some reason, i will keep checking back. I am thinking I might try to make some spacers for the rear cause I am a cheap bastard.
Old May 5th, 2010, 05:00 PM
Number of coils? Are they constant rate or progressive?
90, cover, d90, disco, discovery
Stock D90 springs PJBinDC For Sale - Parts 0 April 16th, 2006 03:37 PM
D90 Springs... arbik Wanted 2 March 25th, 2006 10:09 AM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
