D90 Spray in Liner? - Defender Source
Old May 19th, 2015, 09:43 PM
NAS Addict's Avatar
NAS Addict
Jeff
95 D90 ST #2617
D90 Spray in Liner?
Greeting,
Once again I need the advice of the collective. I am thinking about either Rhino lining or Line-X ing the inside of my D90. Anyone have any lessons learned on this, both pros and cons?
Thanks!
Old May 19th, 2015, 09:57 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Spray everything individually..
Old May 19th, 2015, 10:00 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Line-X is my product of choice, and to be done well the truck really needs to be disassembled. The bedliner goes down heavy and can act as a glue which will bond panels that overlap or butt together. It can be a real nightmare to deal with if you ever need to take the truck apart in the future, so the extra time spent prepping will save you tons in the future. Not to mention the finished product looks much cleaner.
I suggest, after gutting the whole interior, that you remove the floor pans, tunnel cover and seatbox and shoot those pieces separate from the truck, both top and bottom, then reassemble with new seals and hardware for the best end result.
-Ash
Geared Restoration Co.
352-572-3236
Old May 19th, 2015, 10:17 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
What Brewie and Ash said.
That is what I am doing with mine and it just and looks works correct. Additionally, the stainless screws against the black Line-X - :
Old May 20th, 2015, 12:00 AM
SimpleJack's Avatar
SimpleJack
Joe
94 D90 NAS ST
Liner
X3 as stated above on procedures/prep.
I'd recommend a product called U-Pol Raptor liner. I've used it on a jeep and now my 90. I like the finish (seems less rough texture wise than other products), it holds up well and doesn't fade.
Old May 20th, 2015, 01:07 AM
That is what I used on my 90 and my trailer. I'm very happy with it.
Old May 20th, 2015, 10:42 AM
Cal's Avatar
Cal
Cal Thompson
1987/110 3 door ExMod
Don't use Herculiner. The rubber pieces clump up and it looks absolutely terrible. It's cheap for a reason.
90, d90
D90 Head Liner Bill Larson Misc. Chit-Chat 1 September 26th, 2010 12:53 PM
Spray on liner for interior WestTexasDefender Defender Technical Discussions 25 November 25th, 2008 10:11 AM
Spray on mud from the UK Mark M Misc. Chit-Chat 4 June 14th, 2005 03:41 PM
Line X / Spray In Liner ? rcmorgan540 Misc. Chit-Chat 10 June 1st, 2004 02:49 PM
speed liner or rhino liner TDI Guy Misc. Chit-Chat 5 May 5th, 2004 09:27 PM
