D90 solid rotors? - Defender Source
Old July 24th, 2013, 09:17 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
D90 solid rotors?
I'm sick of my vented/drilled/slotted rotors getting packed full of mud. I'm also sick of spending 45 minutes cleaning out every vent and hole after off roading.
Are there any solid rotor options for a D90? I seemed to recall hearing something about military grade rotors or something?
Old July 25th, 2013, 12:08 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
Sure, there are plenty. Try searching on the Atlantic British site. They have tons of options. Here's one:
http://www.roverparts.com/Parts/9995GA.cfm
Old July 25th, 2013, 12:20 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Those are still vented. I'm looking for solid D90 front rotors.
Old July 25th, 2013, 01:14 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
gah...sorry bout that. That's what I get for jumping on the forum while still in the office.
Old July 25th, 2013, 06:30 AM
You can just order the regular old solid rotors. What you'll have to do is take the spacers out of the calipers and get the shorter bolts that hold them together along with the rubber O-rings. You may have to order the caliper seal kit to get just the o rings. These are all on Trevor's website at Rovahfarm.com.
Old July 25th, 2013, 07:27 AM
just use the stock vented calipers, Ive spent plenty of time in mud and have not had issues with either of my trucks.. those cross drilled rotors are silly
Old July 26th, 2013, 05:12 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Once the vented rotors are hot, the mud will dry, contract, and eventually get flung out by centrifugal force as you drive.
Old July 26th, 2013, 05:31 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
Also have never had problems with vented rotors in mud. The drilled and slotted rotors are your problem not the vented.
Old July 26th, 2013, 05:35 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Nope, not in my experience. This mud has been in there for two months and while it's not my daily driver it's had plenty of opportunity to fling the mud out including a 4 hour highway drive at 70mph. If it actually self evacuated I wouldn't care about it being in there.
Old July 26th, 2013, 05:36 PM
transientmechanic
1972 SIII
If the mud has been in there for 2 months and youve been driving it then whats the big deal? It's a Land Rover right?
Old July 26th, 2013, 10:38 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Confused, I thought the stock Discovery front rotors were solid/non vented (my '96 was -- I always wanted to upgrade them to D90 vented rotors but never got around to it)..
Edit: Okay, I see you mention D90 even though your photo and vehicle are listed at 1998 Discovery. I goofed reading your post, sorry. However, maybe that is your solution, you can swap in Discovery front rotors and calipers. I'm sure you can find a Discovery owner that would swap with you, I wanted to move to vented rotors when I had my Discovery..
~Scott T.
'95 D-90 ST - AA Yellow
Old July 27th, 2013, 12:08 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
The problem is there was quite a bit of mud in there and it was actually causing vibrations.
I have a D1 I upgraded the brakes to D90 stuff because they were supposed to be the shit.
I just thought I had heard about some solid thicker rotors for D90's, military grade or something.
Old July 27th, 2013, 07:09 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
But do you have experience with stock D90 rotors? You say yours are drilled, which isn't stock.
Probably the reason the mud is staying in them is because of the drilled holes. Those fill with mud too and probably act like locating pins for all the mud inside each vent, so it can't get flung out, even when it's dried.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 27th, 2013, 11:58 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I am switching my NAS 110 from Solid to D90 Vented. The rotors I have on there are brand new, with no miles to speak of, but I now purchased the Wider (Spaced) D90 Calipers and Rotors, so if you would like, I would sell the factory 110 calipers and new non-vented rotors cheap if you want them. Let me know, I guess it would give me the shove I need to finish that job. haha
d90
Will Calipers and rotors from a 10 spline D90 work on a Disco Axle tomaco1 Defender Technical Discussions 13 December 14th, 2010 11:16 PM
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
D90 rotors, pads artm Defender Technical Discussions 12 April 12th, 2007 01:19 PM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
