d90 screwed me today! HELP!!!! - Defender Source
Old December 1st, 2003, 06:52 PM
vesparover's Avatar
vesparover
brian bertolini
Angry d90 screwed me today! HELP!!!!
Hey everyone, today my 95 defender left me stranded on a bridge. I turned it off while I waited for 10 minutes (it was a drawbridge). When I went to restart it, everytime I turned the key the lights would shut off on the dash and nothing would happen! I pulled the seat off to check the battery connection but all was well. I recently ran a new 0 ga ground, and 0 ga alternator cable. If I played with the ignition key it would sort of short out the lights on the dash. So I pulled apart the dash, took the ignition out and disconnected it. I tried to hotwire the thing as there are only four wires. I couldn't get it to fire up. Does anyone know which wires I need to connect to start it. Does this sound like the problem to everyone too?
Brian Bertolini
Old December 1st, 2003, 08:00 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Ignition relay. Take off the fuse box cover, should be farthest on the right. Pull it and swap out another one and crank. That should be it. Almost positive!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 2nd, 2003, 10:22 PM
vesparover's Avatar
vesparover
brian bertolini
you were so right about that damn relay. i don't know what it is lately but i have had to replace all of the fuel injection relays last week too! All at once I guess.
brian bertolini
Old December 2nd, 2003, 10:56 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
glad I could help. Take a look at the main grounds when you have the time. Might be causing the relays to get hot which leads to failure. Might also just be time for them to go!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 2nd, 2003, 10:59 PM
vesparover's Avatar
vesparover
brian bertolini
what do you mean my main grounds? as in the battery ground and engine ground? anything else?
thanks again for your help.
brian bertolini
Old December 3rd, 2003, 10:49 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Just what you said. Most importantly, the main from the negative of the battery. There should be a frame ground on the passenger side too. If you want to be sure, run a ground wire from the negative post on the battery to the body also. It is just a little insurance. A good ground will help all your electronics work longer.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
90, d90
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
