d90 running cooler - Defender Source
Old January 19th, 2010, 06:11 PM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
1997/D-90 Station Wagon
d90 running cooler
is it possible to get my engine running cooler?..it just runs really hot...expansion tank always overflowing like it's supposed to when it gets too hot but I'm sick of it...any ideas pertaining to running your engine cooler
can I perform surgery and alter the placement of my cool air intake to where it's taking in air directly from one of the vents on the hood?
I wonder if I can drive over that..?
Old January 19th, 2010, 06:14 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I'm really, really happy with my new setup. I posted it under the small projects section.
And hay
And I love you too
Old January 19th, 2010, 07:30 PM
New radiator.
Old January 19th, 2010, 07:43 PM
and head gaskets and thermostat
Old January 19th, 2010, 08:36 PM
I would have your radiator cored...and check your thermostat.
Old January 19th, 2010, 08:54 PM
huck1974's Avatar
huck1974
shane cates
94 d90
water pump also
And hay
And I love you too
Old January 19th, 2010, 09:22 PM
imeek
Isaac
Red 94 D-90 (SOLD)
I just had this problem, where my truck was running hot (always spewing it's guts from the expansion tank). It ended up being a head gasket (and partially blocked radiator). When you are doing a head gasket, as thermostat is cheap insurance.
Try out one of the hydrocarbon detection kits from autozone. That should tell you if it's head gasket time.
Old January 19th, 2010, 09:47 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
2nd hydrocarbon test. Easy, quick, and available at Napa as well. Usually in the $50 range.
Old January 20th, 2010, 02:34 PM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
ok I'm gunna try the hydrocarbon test and figure out if it's the head gaskets...which it sounds like IRS gunna end up being from imeek
Old January 20th, 2010, 04:08 PM
might as well start ordering parts. I had same issues in my CLassic new gaskets etc, no more bubbles.
Old January 20th, 2010, 04:57 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Might also be the fan clutch.
Old January 20th, 2010, 09:25 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I have an extra one of those if needed.
And hay
And I love you too
Old February 1st, 2010, 02:12 PM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
How would i check if its the fan clutch? where is that located on the truck...im not sure I know what that is
Old February 1st, 2010, 02:24 PM
the fan clutch is what the fan mounts onto, it is mounted to the water pump. i think its like a 1/1-4 nut.
Old February 1st, 2010, 10:07 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
32 mm will work also, and very thin.
You can get one on eBay for 10$.
- Charles Eames
Old February 2nd, 2010, 12:15 AM
jaygoss's Avatar
jaygoss
Jay Goss
'60 Series II Station Wagon
You've probably already checked this- and I doubt it would cause the problems you're having to the extent that you're having them, but make sure your radiator fins aren't covered in dust/dirt/crud. I recently took mine through some stuff and noticed it was running a bit hotter than normal (no excess in the overflow tank- just a little hotter on the gauge). When I was checking things out I noticed the radiator had a light brown color from the dust/dirt that was a result of my exploits. It wasn't really apparent at first- and didn't jump out at me as being blatantly filthy. I sprayed down the radiator- front and rear with a low pressure stream until it was clean. The temp gauge is now indicating the normal heat level when it reaches operating temp.
Again- I'm sure you probably have already checked this...and there are probably a lot of people saying, "duh...who brought the cool kid" when they read this...but I thought I'd mention it in case it saves you some of your hard earned $. Hope it's a simple, cheap fix for you. Good luck.
1960 Series II 88" SW
1994 D90 ST Arles Blue (sold)
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic SWB TWR edition (sold)
Old February 2nd, 2010, 12:55 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Don't forget, fan clutch is reverse-threaded.
Old February 2nd, 2010, 09:30 AM
I didnt think it was on the serpentine trucks.
90, d90
WTB: Running boards for D90 pmd Wanted 1 March 7th, 2006 08:07 PM
WTB 97' D90 auto transmission cooler pendy Wanted 15 September 28th, 2005 08:12 PM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
ARB Bumper 97 Transmission Cooler Caution dnewman9 Defender Technical Discussions 4 September 8th, 2004 12:51 AM
