D90 rollcage spread - Defender Source
Old November 13th, 2006, 02:56 AM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
D90 rollcage spread
I removed the front crossmember from my rollcage in order to change the vent seals on my '97 D90. I didn't get around to putting the crossmember back on for about a week, and now the rollcage seems to have spread out. In other words, the bolt holes no longer line up! I can get the bolts back in, but they are angled and won't tighten fully as a result. Any thoughts on how to remedy this "bind". Thanks in advance!
Heston
Old November 13th, 2006, 06:33 AM
Use a rachet strap to get it to line up.
Ron
Old November 14th, 2006, 01:05 AM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
Not sure what a rachet strap is -- is it like a motorcycle tie-down with the racheting gear?
Heston
Old November 14th, 2006, 01:39 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Yes , basically. Any hardware store sells them, in red or blue sling material, 1", 2". the ratchet looks like a buckle on a large pin, and each end has a hook. When you buy it, it will be self explanatory .Your basic rigging stuff that you should also use for tying things down on roof rack. Obviously if you are going to use it as a double end puller, the larger the ratchet strap the better.
Old November 14th, 2006, 12:38 PM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
thanks guys!
Heston
90, cage, d90
1994 D90 Fiberglass top and NAS Rollcage abraded For Sale - Parts 4 January 9th, 2008 10:33 AM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
