D90 Rear Inner Axle seal? - Defender Source
Old July 7th, 2009, 10:16 PM
Gibson04
Justin Church
1994 D90 / '04 Disco
I have diff fluid dripping down the inside of my rear driver's side brake rotor. It's enough to put several spots on the concrete as well as rust proofing the undercarriage.
I have searched and havent found a definitive answer.
Does it sound like the inner seal?
Please point me in the direction of a decent writeup of replacement.
Thanks in advance
Old July 7th, 2009, 10:53 PM
First, unclog your breather tube and make sure it is clear. Then go down the list of faults with the most reasonable suspect being the inner seal.
Old July 8th, 2009, 09:56 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
After you unclog your breather tube as Ron suggested, you can also convert to wet hubs by removing the inner seals and replacing the hub seals with part# RTC3511. It is a much more robust seal with dual lips.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old July 8th, 2009, 12:07 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
You can use the RTC3511 with grease also.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 8th, 2009, 01:10 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I second that!
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old July 8th, 2009, 01:22 PM
Gibson04
Justin Church
Thanks Guys....
I am planning on taking the banjo bolt loose tonight that holds the breather tube on and making sure it is not clogged. then refit and drive on the highway abit to see if slows the leak down any. To get to the inner seal ....I am guessing that I will have to pull the halfshaft, take the brake caliper off and then remove the entire hub?
what size is the hub nut? Im not sure if I have a socket that big.
Justin
Old July 8th, 2009, 01:57 PM
I second this. No reason to go to wet hubs.
Originally Posted by Gibson04
Thanks Guys....
Justin
Hammer and chisel or channel locks.
Old July 8th, 2009, 05:12 PM
Its a 52mm.
Old July 8th, 2009, 06:52 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
It will eventually stop leaking on its own.[img]images/smilies/happy.gif[/img]
Old July 8th, 2009, 07:09 PM
Sure there is. When you have wet hubs and the hub seal goes, it leaks and you know it has gone......before you go wading. With grease filled seals, when the seal goes, you don't know and then you destroy the bearings in the middle of your off road trip.
Old July 9th, 2009, 06:46 AM
Gibson04
Justin Church
Update..... breather tube was completely blocked where the banjo fitting meets rhe hole in the bolt. I cleaned it all up and I will drive it to work to see if this has helped.
Thanks again foryour suggestions.
Old July 9th, 2009, 06:50 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
It seems this is obviously a common problem, instead of fitting a wading 'kit' would just drilling out the housings and tapping them NTP for a larger press-in breather make more sense? It would seem that just cleaning them out is asking for it to happen again.
Old July 9th, 2009, 08:42 AM
Gibson04
Justin Church
Im not sure but it looked as though the clog was caused by the mixture of diff oil and Uwharrie Dust. A few sprays of brake cleaner and problem solved.
I really can't imagine having to do this very often. Probably just years of buildup.
Old July 9th, 2009, 09:52 AM
Did you blow air through it to make sure the line was not blocked at the top too?
Old July 9th, 2009, 10:22 AM
ajh
Andrew J. Hutton
I read somewhere that clogged breathers were also an issue when using an air-locker and contributed to seal failures (in the locker), either way I am going to open mine up a bit and make sure they vent nice and high.
Old July 9th, 2009, 10:58 AM
Gibson04
Justin Church
Brake cleaner and compressed air.......damn near blew the brake cleaner back on me once the clog came aloose.
Thanks for the tip Ron
90, axle, d90
New Type of Drive Rear Drive Shaft for D90? DJ Menasco Misc. Chit-Chat 18 July 19th, 2004 06:41 PM
Rear main seal replacement howellm70 Defender Technical Discussions 4 May 20th, 2004 07:33 AM
D90 SW rear wheel carrier mdmccallum Defender Technical Discussions 14 January 27th, 2004 02:45 PM
OME shocks are too long on rear axle... wicks Defender Technical Discussions 5 October 6th, 2003 02:39 PM
