D90 Rear Bench-Seat Install - Page 3 - Defender Source
Old March 24th, 2012, 03:25 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Originally Posted by rijosho View Post
Sure - if you don't think $900 each + shipping isn't expensive.
Yep. Basically, $900 x 2 + 2 brackets + shipping from the UK. My guess is $2500? But I do suspect they'll come down in price. Eventually. I'd get them if they were around $1500 overall.. but it's just too much dough now.
To Rons point, I think you can pull only the rear window trim and make the bracket/seat belt fit.. Side can stay.
-Ren Ching
Old March 24th, 2012, 03:32 PM
StphNieuw's Avatar
StphNieuw
Stephan
Former owner of a 84 D90 RHD 2.5 NA
Not sure how I missed the 900 dollar tag, thought it was 250 or so.. Oops
------ Follow up post added March 24th, 2012 03:36 PM ------
Actually take a look at the following. Its 230 at lucky 8
http://www.lucky8llc.co/index.php?pa...mart&Itemid=13
Old March 24th, 2012, 03:39 PM
smob's Avatar
smob
Steve
Actually take a look ate following. Its 230 at lucky 8
We mean the new lock & folds.. which also come with the seat belts. And Justin has them for $812, which is a nice price drop from a month ago or so.
-Ren Ching
Old May 20th, 2012, 11:25 PM
Funtogun
Robert Lewis
1994 D90 ST
Hey guys, new D90 owner here...didnt want to start a new thread. I have everything but the bolts that mount the seat belt to the cage on a 94 ST. There are tubes there that the hanger fits around, however they do not appear to be threaded unless it is threaded deep inside the tube. The triangle shaped hanger slips over the tube that extends out of the cage, I am missing the hardware that bolts it into the cage. Any ideas on where to get these parts? Your help would be appreciated.
Old May 21st, 2012, 07:07 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Robert, I got your email as well and will check for you later but if memory serves the bolts are M10 and I believe the thread pitch is 1.25 but will double check for you. As for the length, I believe I used 60mm on mine
Old May 21st, 2012, 10:16 PM
Funtogun
Robert Lewis
1994 D90 ST
Jefhuf...I appreciate your help. The M10 appears to be correct as is the 60mm...However the 1.25 pitch is not working for me.
Old May 22nd, 2012, 05:50 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Well, 2 out of 3 ain't too bad! I didn't get a chance to pull a bolt last night but will pull one tonight to see if I can determine the thread pitch for you
Old May 22nd, 2012, 08:20 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I checked the bolt I have tonight and it looks like it is actually a 65mm but not sure that makes that much of the difference. As for the pitch, it appears to be a standard 1.5
Old May 27th, 2012, 04:57 AM
Funtogun
Robert Lewis
1994 D90 ST
Thanks..Im going to have to try to come up with a couple of them. Thanks again-
Old May 27th, 2012, 08:08 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
If you cannot find locally at an ACE hardware or maybe Sears Hardware, you can get them online from either McMaster or BoltDepot
Old May 27th, 2012, 08:53 AM
Any idea what thread the bolts are that secure the seatbelt reel to the tub?
Old May 28th, 2012, 08:56 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I can double check but pretty sure they were just a standard thread M10 or M12 bolt
Old May 28th, 2012, 10:59 AM
Funtogun
Robert Lewis
1994 D90 ST
I think it is a M12.
BTW..I learned a little trick to getting the upper bolt for the sear belt hanger in today. My roll bar had shifted making it impossible to thread the bolt in, as it was not aligned properly. I used a reversed clamp to spread the cage from the rear bar to the hoop. It moved it enough to be able to thread the bolt. It sure beats tearing up your padding trying to pry it over.
Thanks for your help on this.
90, bench, d90
D90 Rear Bench Seat tadams For Sale - Parts 2 December 14th, 2005 10:31 PM
Wanted: Rear Bench Seat & Safari rack TND90 Wanted 0 November 26th, 2005 06:54 PM
Rear Bench Seat oldscratchggf Wanted 8 August 19th, 2005 12:04 PM
97 st Stock Springs/ rear bench seat Britt Easterly For Sale - Parts 4 May 29th, 2004 03:08 AM
ST rear (bench) seat w/seatbelts Art Vigil Wanted 2 April 11th, 2004 05:22 PM
