D90 randomly stalls when placed to neutral - Defender Source
Old May 9th, 2007, 12:16 AM
danb.taylor
Taylor
After my D90 gets warmed up, it sometimes stalls when I am coming to a stop and have placed the vehicle into neutral. Other than that the motor seems fine. Any ideas?
Old May 9th, 2007, 01:17 AM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
Does it stall suddenly, or does the idle drop so low that it stalls? If it's the former, then it may be an ignition or fuel problem. If it's the latter, reset the base idle then check/clean the stepper motor as a start.
Old May 9th, 2007, 09:03 AM
That used to happen to me in my Disco I. What I found was that there is a little bypass channel at the start of the intake, right underneath that idle allen screw that you aren't supposed to touch, that get's clogged after a while. you can see it by taking off the hose section between the MAF and the intake, and looking into the chamber where the throttle plate is. When the throttle plate is fully closed (at idle) that little bypass allows enough air to get in to maintain idle. when it gets' clogged, no air.
get some carb cleaner, stick the straw on it, and shoot it in there, and watch the gunk come out. Also, as Jim mentioned, clean off that stepper motor, because it is surely gunked to, and that little chamber leads to the stepper.
90, ac, d90
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
