D90 radius arm bushings question - Defender Source
Old July 12th, 2016, 11:00 AM
jashof
Jason Hoffman
1986 90, RHD 200TDI
I bought an 86 rover 90 that was missing the washers in front of the bushings on the threaded end of the radius arms not back bushings but the ones in front of the frame bracket. Anyway I sent my arms out to be cranked by RTE. when I reassembled, I was referring to a parts diagram and noticed these were missing. I ordered a set but they showed up the afternoon I left for an overland tour across British Columbia. Anyway now the bushing on the one side is shredded making steering near impossible above 40mph and causing the arm to rub on the frame. I'm trying to source the part locally but I'm wondering if the disco series 1 arm bushing may be the same part as the defender? If so , that is at least more common.
Old July 12th, 2016, 11:06 AM
The chassis end radius arms bushings don't change. Disco 1 bushings are the same. Crazy that you did not die without the front washer.
Old July 12th, 2016, 11:18 AM
Just to clarify.... are you suggesting a washer between the bush and the chassis?
Allbrit.de - Ersatzteile für LAND ROVER & MG ROVER
Old July 12th, 2016, 11:46 AM
NRC4515 I'm guessing. You're right, he'd be missing a front axle without the big washer under the big nut.
Old July 12th, 2016, 11:51 AM
To be clear... DA2353G | Front Radius Arm Bush Kit - Paddock Spares shows a complete kit of all parts used on a radius arm chassis end bushing set. Two bushings, two washers (one plain and one curved) and a nut.
Old July 20th, 2016, 08:47 AM
jashof
Jason Hoffman
1986 90, RHD 200TDI
It was the curved one I was missing.
90, bushings, d90
Where Can I get Blue polybush radius arm bushings sflash868 Defender Technical Discussions 2 December 19th, 2013 05:11 AM
Radius arm size question jayz Defender Technical Discussions 4 September 3rd, 2012 02:05 AM
Radius arm and trailing arm nut size dave_lucas Defender Technical Discussions 3 February 25th, 2010 03:44 PM
Radius Arm Bushing Question Craig T Defender Technical Discussions 4 April 16th, 2009 08:02 PM
Slotted Radius Arm Bushings -- Opinions? LRNAD90 Defender Technical Discussions 7 June 19th, 2006 10:37 AM
