D90 radiator - Defender Source
Old November 21st, 2010, 09:31 AM
maleger
Marc-Andre Leger
D90 radiator
What is the general consensus on radiator replacement options for a 1994 NAS D90 ?
I'm installing a Kenlowe fan and noticed a lot of oxydation (green stuff) on the radiator and some leakage on the pipes, so I figured I'd just replace it before installing the electric fan... Not sure what to put in.
Old November 21st, 2010, 11:18 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Options:
- get a clean used one
- be lucky and find an new old stock
- go with a different route and get two: one for the oil, one for the coolant
- go with a coolant radiator and ditch the oil cooler
- recore your radiator (I understand that Pendy here can do a phenomenal job, no personal experience)
Personally, I plan on recoring (likely do it myself as a project since I have a spare I can do this with).
Good luck!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old November 21st, 2010, 02:45 PM
willismatt25's Avatar
willismatt25
Matt S
1994 D90
Get a new one! My $.02
Bryan @ http://www.alumrad.com/ did a great job for me on my LS2 conversion. He has the specs for the D90's and was less than a 2 week turn around.
Old November 21st, 2010, 08:26 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Get an allisport all alloy one and never need to worry again.
Old November 22nd, 2010, 09:09 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
You put an LS2 into a 90? You got any photos of that project?
Old November 22nd, 2010, 07:10 PM
willismatt25
Matt S
1994 D90
Yep
Its in the "truck build up's and restores" area.
http://www.defendersource.com/forum/...ad.php?t=27138
Old November 23rd, 2010, 12:22 PM
maleger
Marc-Andre Leger
The Allisport looks like the best choice for me. Any ideas on which model I would need ?
Their eBay store says : Also available with integral oil cooler if required (for example NAS spec auto vehicles)
Do I need an Oil cooler for a LT77?
Old November 23rd, 2010, 01:47 PM
ajh
Andrew J. Hutton
Talk to Andrew on the phone, he's very helpful, just make sure you're 100% specific on your setup. He also does an alloy overflow tank that looks nice and won't split.
The oil cooler is for the engine and you do want it, an oil cooler is basically the only cooling the bottom end gets, the coolant is mostly for the top-end.
The LT77 (AFAIK) does not have an integrated oil pump like the R380 does, so you can add one but it's a much more involved setup. Personally I'd save up for an R380 if the LT77 goes now that Ashcroft is doing the short-bellhousing one again (they started a month after I got my used one fitted, and having a new one would be really nice).
I think Allisport also do an alloy rad frame, and if you've got the cash available go for their full-width intercooler at the same time and get them to assemble everything in advance, I've see the setup and it's sweeeet.
Old November 23rd, 2010, 02:28 PM
What is wrong with stock? Roverguy had them for ~$600.
Old November 23rd, 2010, 02:46 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I got a spare one too and I'm gonna get it recored then save it for when my 110 overheats or whichever. This guy around the corner from my house has a shop called buzzards (as in the scavenger bird) and he showed me different cores and just how much more cooling percentage wise I'd get from recoring and he said its not much but its better than nothing. Cost would be around 550 bucks with new core and sealed/tested.
Robert Deniro
Old November 23rd, 2010, 09:00 PM
maleger
Marc-Andre Leger
Allison
The Allison store ( http://cgi.ebay.co.uk/AlliSport-Defe...item4cf2162fe4 ) shows the cost to be about 779$US once converted. From what I saw in my research is that this is the most solid solution (Dakar tested apparently) and best heat dissipation from Alu without the oxydation issues of copper. If I buy something in the USA, I still have to pay shipping and customs, so this is not a big difference in the end.
90, d90, radiator
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
New In Box D90 Radiator Leftover Parts willtillery For Sale - Parts 0 February 15th, 2006 11:15 AM
D90 Radiator Panel (Surrounds the Grille) RyanS Wanted 2 February 9th, 2006 02:12 PM
1995 D90 NAS Frame, 3.9L V8 & Radiator for sale Barnett Childress For Sale - Parts 10 June 22nd, 2005 07:38 PM
leaky/bad '97 D90 Radiator kiphartzell Wanted 8 April 11th, 2005 03:42 PM
