D90 Out Of Controll !!!!! - Defender Source
Old April 13th, 2006, 08:25 PM
Rover- Girl
Guest
Posts: n/a
Question D90 Out Of Controll !!!!!
I recently had a OME kit installed, then had the drag link and tie rod bushings replaced..
I was told that I need an aliment after the installment of the bushings and such..
( hence, the steering wheel is completely of center)...
I was going to drive like this until my next maintenance appt.
However, I have noticed the truck is veering almost out of control when applying the
brakes or making a sudden lane change
Is it just the alignment I need or is something else wrong here !!??
FYI... will have the truck align tomorrow....just to be on the save side!
Thanks Christine
Old April 13th, 2006, 08:34 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
Alignment can definitely do this, especially with a little lift and bigger tires.
I had a similar problem, and it turned out one of my rear trailing arm nuts was loose. Even when I would let off the gas, it felt like it was going to swerve out of control. I was told it could be loose or the bushing need replacing but it was just loose. You can check these easily, they are rods from the rear axle and connect to the frame just in front of the rear wheels.
Hope this helps...
Bill
Old April 13th, 2006, 10:59 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Most likely, yes, the new springs and everything else have the front end really far out of whack. IIRC you were going to do all new tie rod ends and steering joints too right? Did you have those done as well? Most likely that is what is causing the issue you're having, and why the mechanic said to get an alignment. Changing those parts can really alter the entire steering geometry.
I'd suggest you definitely get it aligned first chance you get. When you get it done, make sure to tell them what else you had done, and to make sure that they check all of the steering and front end linkages. Otherwise they might just line up the tires and not fix the steering issue too.
But that is probably all you need.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 14th, 2006, 09:46 AM
Rover- Girl
Guest
Posts: n/a
Great, that's what I thought too, just wanted to hear it from the "REAL ROVER PROFFESSIONALS"
Christine
90, d90
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
