D90 not starting - Defender Source
Old January 26th, 2012, 01:43 AM
Spook's Avatar
Spook
Rich
97 Defender 90
D90 not starting
Swapped over some bulbs to LEDs tonight and now she won't start. Fuel pumps is on, lights on dash are on, I hear the key in ignition/light buzzer, but no cranking... Fuses look fine. I can't really test relay but I did swap out a couple under the dash with each other for trouble shooting. Also, I tried to put into reserve and then back to park to make sure it was set and it's locked.
Thoughts?
Thanks.
Old January 26th, 2012, 06:02 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Did you check the battery?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old January 26th, 2012, 10:11 AM
Spook's Avatar
Spook
Rich
97 Defender 90
Yep. 12.8v. Everything turns on pumps, lights, buzzer.
Old January 26th, 2012, 10:20 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
DO you hear anything when you try to crank it, ie starter, etc??
Any problems with the ignition tumbler?
DO you have an alarm? Try removing the key from ign, arming alarm, diasrming and try cranking engine. If you were under the dash all I can think of is a lose wire.
Good luck.
John C.
Old January 26th, 2012, 01:57 PM
Spook's Avatar
Spook
Rich
97 Defender 90
No the radio stays on and the door buzzer goes silent. I am at a friends shop now. Hope to update soon.
Old January 26th, 2012, 02:01 PM
If you're not even getting door chime, or intermittent success with some things and not others, check your ignition module - on the opposite side of where your key goes into.
http://www.defendersource.com/forum/...ad.php?t=26677
Old January 26th, 2012, 02:03 PM
JohnC
Yep, I've had two fail on me on my Discos (which look just like the D90 ign).
John C.
Old January 26th, 2012, 04:27 PM
Spook's Avatar
Spook
Rich
97 Defender 90
So th deal was....I popped the one of the light fuses which was tied to the ignition (same circuit) and there ya have it. Go figure.
90, d90, start, starting
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
D90 starting issues - could it be Snorkel related? pmd Defender Technical Discussions 7 January 9th, 2009 12:47 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Help With Starting My D90! Davis Defender Technical Discussions 0 September 7th, 2004 05:13 PM
