D90 NAS looking for a 4.6 swap ? - Defender Source
Old August 16th, 2015, 07:51 PM
axis007
Chen
94 D90
I need some advise please, i own a 94 D90 NAS since 1998. The 3.9 is tired, i am seeking for some advice for a new motor. I am seeking more power as the 3.9 is under powered by mine standard. I have some questions
1. Replace with a 4.6 long block, i understand the cost is not cheap ? Does anyone have a ball park cost ? Is the extra 30-35hp make a noticible difference ? ( i have 33 inch tall tires which did slow down the acceration fromthe stock 31 inch ) can i still use the top end ? Injectors, intakes ECU ???
2. Any other solutions ?
3. Small block Chevy conversion ? 300hp is nice, but the originalness and possible collectibility is shy me away the GM conversion !
Please offer me your .02
Or link to forums that may have covered this discussion.
Old August 16th, 2015, 07:56 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I notice the difference in having a 4.6 in my 1994. I'd do it. If I had to do it all over again and I had the money, then I'd do the LS swap (Plenty of info on this forum). That would be my #1 choice. My #2 would possibly be a 300 tdi or 2.8 diesel. But again, you are talking many thousands of dollars.
You can pick up a 4.6 pretty cheap at a junk yard and swap over or rebuild to a nice level. Still get 13-15mph, a little more torque/horse, but I definitely feel the difference.
If I did go the 4.6 route, I would swap at your 1994 v-belt distributor driven oil pump cover and go with the crank driven oil pump of the serpentine set up. better oil pressure, better life. Yes, you have to swap over a few ancillaries, but it is worth it. The distributor driven oil pump is a joke once it is worn in. 4-12 lbs of oil pressure sucks. My idle now lives around 20 and just goes up from there...and that is good for an engine.
Old August 16th, 2015, 08:09 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I was in the same position you are last year. My 3.9 was very tired and needed a rebuild. I decided to best route for me was sticking with the 3.9, but putting a cam, dual row timing chain, and high flow heads on it. It kept the stock appearance and all the stock parts, but runs very well. I ordered the engine from Turner Engineering, got it in 3 days, and swapping was very easy. I don't have any objective measurements of performance, but it holds its own with a Forerunner in a drag race, FWIW.
Angus
Old August 16th, 2015, 09:17 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
If you had a 4.0, then it's a heck of a lot easier to go the 4.6 route. But if you want to keep the rover engine just because and for sentimental value, then maybe you should consider getting a 4.0 and have it rebuilt and stroked for 4.6. Just pick up a tornado chip to get the full effect of the 4.6.
I'm going the 4.0 (NAS 97) to 4.6 because I do want to keep the rover engine. If I do the import route, then I'd definitely swap in an LS3.
Old August 16th, 2015, 09:23 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
LS conversion if you are staying with a gasser. Use the search function, there is ample reading on the subject.
Old August 17th, 2015, 08:28 AM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
I went from a 3.9 to a 4.6 with a crower performance cam and the tornado chip. Noticeable difference. If you want to stay "original" but crave more power, this is certainly the way to go... It's also very costly.
Old August 17th, 2015, 10:19 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I went from a 3.9 to a 4.6 (D & D cam, lipped liners, mild attention to ports, 5.0 injectors) in my 94 D1, (which has serpentine belt driven accessories). Very pleased with the difference in power/torque. Not sure I ever checked fuel economy- big tires, gearing changes, lots of heavy equipment, massively lacking aerodynamic efficiency. Don't have the disco any more, but still have the engine....
There is a guy who purchased a 4.8 from :
Rover V8 Engine - V8 Performance Engines - Land Rover Engines - Jaguar engine Off road racing and he is fitting it this week. I was supposed to do the install, but my schedule got jammed up and he found someone closer to home who could do it sooner- so I don't have any firsthand knowledge of the quality of the product.
Email is
Same place, new dogs.
Old August 17th, 2015, 11:19 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Your question is a valid one but when you tally the votes my money says you will be equally puzzled. The best recommendation I can give is find a well carried out 4.6 set up and drive it. The incremental differences between 3.9/4.0 to 4.6 is something you should really judge by the seat of your own pants.
IMO the guys serious about V8 performance and reliability and not worried about a green oval on the manifold are doing LS3's.
Old August 17th, 2015, 12:12 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Originally Posted by Roverlab View Post
I went from a 3.9 to a 4.6 (D & D cam, lipped liners, mild attention to ports, 5.0 injectors) in my 94 D1, (which has serpentine belt driven accessories). Very pleased with the difference in power/torque. Not sure I ever checked fuel economy- big tires, gearing changes, lots of heavy equipment, massively lacking aerodynamic efficiency. Don't have the disco any more, but still have the engine.... There is a guy who purchased a 4.8 from : Rover V8 Engine - V8 Performance Engines - Land Rover Engines - Jaguar engine Off road racing and he is fitting it this week. I was supposed to do the install, but my schedule got jammed up and he found someone closer to home who could do it sooner- so I don't have any firsthand knowledge of the quality of the product.
I miss making popcorn on the backseat passenger floor.
Jimmy Buffett
Old August 26th, 2015, 04:12 PM
Peter 333
Peter
D90
Engine swap
I'm right behind you. My engine is tired as well. Where are you planning on having the work done. Please keep me posted thanks.
Old August 26th, 2015, 04:17 PM
1of40's Avatar
1of40
1of40
Anyone have a sense of what the que is for an LS conversion being done by a bonded and insured shop with a solid rep and pedigree? Much more fun then investing in a mutual fund, right?
90, d90, nas
Carb rebuild vs FI swap vs engine swap samer0214 Defender Technical Discussions 14 July 13th, 2014 08:33 AM
1994 NAS D90 Tdi auto swap Broncoduecer Truck Build-up's & Restores 14 January 25th, 2014 04:47 PM
I want to swap out my 94 NAS ST doors for roll up windows flananuts Defender Technical Discussions 12 August 25th, 2011 05:58 PM
NAS 90 Frame Swap with a budget SafariHP Truck Build-up's & Restores 50 September 30th, 2010 12:12 PM
Looking to swap 95 ST for 95 / 97 SW unit3a Wanted 0 November 28th, 2008 12:55 PM
