D90 NAS crossmember - Defender Source
Old July 9th, 2015, 08:36 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
D90 NAS crossmember
Yes, I researched the forum, then Google. But the more I research the more questions I have.
I have a 94 NAS d90 soft top. Needing crossmember work. A buddy says we can patch weld it, but I'm thinking about swapping it out.
I'm finding different products available. Some with deeper sleeves to slide over the originals. Most if not everything I found state "NOT NAS". Something to do with reusing the tank cradle. Is that a big deal?
Also any tips on building a jig? Plywood jig off the original dimensions. What points of reference do you recommend? Stupid questions? Sorry!!!
Anyone know of a step by step guide that I can reference?
Thanks in advance.
Old July 9th, 2015, 08:43 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You can modify a non NAS to work with it. We only sell the full quarter chassis for NAS now because of the cradle issues.
What I'd do personally is what Michele and Brandon have done, redesign it completely(if you have the time)
Old July 9th, 2015, 08:56 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Excellent. Ok now, what does all of that mean? Haha. Seriously, who are Michele and Brandon? Any links that I can check out? Redesign what? Anything available retail that I can buy? My welding skills involve buying dinner and beer for my best friend to do it for me.!
Old July 9th, 2015, 09:01 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
http://www.defendersource.com/forum/...on-63351.html#
Brandon has photos somewhere, he's user BRAB on here
Old July 9th, 2015, 09:08 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
If your going to do it buy the quarter chassis and cut it up, don't try to make an ROW fit. No offense Zack but the ROW has a bunch of holes that the NAS doesn't have and takes twice as long to modify and cut to make fit. Easiest and best way is to cut just in front of the fuel tank cradle (don't forget the wiring harness is in there) and replace the entire section. Just my two cents from someone who has done a half a dozen over the past six months.
Old July 9th, 2015, 09:52 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You're not offending me, I would never suggest someone use the UK/ROW style instead of buying a NAS. Some people just don't want to spend the $$ on the proper setup.
Old July 9th, 2015, 10:06 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Good stuff. Any suggestions on drafting up a jig?
Old July 9th, 2015, 10:19 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
rovers north sells the NAS rear cross member with the cradle..
good luck with your search
Old July 9th, 2015, 10:24 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Indeed...feel free to PM me for a price. Shipping is definitely pricey because of its size it has to go truck.
Old July 9th, 2015, 10:43 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Thanks Zack. Pm'ing you now.
Old July 9th, 2015, 10:50 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Anyone who owns a NAS and is worried about a saving few hundred bucks to do a job the wrong way that will ultimately devalue their truck is an idiot in my opinion. And I would never lead someone to believe that it is a viable solution, bc then I look like an ass when they have to spend 20 hours to do an install. Just my opinion, can you make it fit? Sure, but I can make anything work/fit with enough time, that still doesn't make it right...
90, d90, nas
d90 NAS rear crossmember rwillms For Sale - Parts 29 September 16th, 2013 08:32 PM
Rear Crossmember & Fuel Tank Cradle for NAS D90 question Rufus Defender Technical Discussions 53 November 29th, 2012 10:54 AM
Replacing Rear Crossmember on a NAS D90 Manimal Defender Technical Discussions 7 May 21st, 2011 02:59 AM
Replacing the rear crossmember in a NAS 110, what do you do with the "saddle" evilfij Defender Technical Discussions 21 June 2nd, 2010 07:54 PM
Folding rear step on NAS rear crossmember Overlander Defender Technical Discussions 4 September 15th, 2008 09:33 PM
