D90 low fuel waring light - Defender Source
Old May 24th, 2009, 05:50 PM
RoverC
Cliff
1997 D90 ST
Has anyone ever figured out how to make the low fuel warning light work on a D90?
Change the gauge? Different fuel pump?
thanks
Old May 25th, 2009, 06:26 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Hi Cliff!
On UK rovers it's a separate wire from the sender unit (on the tank) up to the dash.
Td5 rovers, the light it controlled by the speedo which has a dampening circuit in it, (to stop the guage from waving about frantically when you go round bends) but it also controls the light.
Old May 25th, 2009, 07:45 AM
oldgreentrucks's Avatar
oldgreentrucks
Jim Pace
The NAS model has power going to the dash indicator light and needs to be grounded to turn on. Assume the UK model has the correct ground from the tank sending unit?
Old May 25th, 2009, 01:00 PM
RoverC
Cliff
1997 D90 ST
I would have thought someone would have done this before, like ECR etc.
youre sure there is power to the light?
I have an old fuel pump/sender but dont see anywhere for a wire to attach
Old May 26th, 2009, 09:29 AM
oldgreentrucks
Jim Pace
If you open the dash panel to gain acces to the back side of the light and Ground that location (don't recall exactly which one but obvious when looking) it lights up red with a fuel pump symbol. I was wiring my D90 up as as indicator for a transfer pump "on" with aux fuel tank. The hot comes in through the standard panel wiring. Requires a little work to locate/fabricate a connector that fits into the factory socket. Seems the correct "ground" signal coming from the fuel tank sending unit would work? But electrics are not my strong point.
Jim
Old May 26th, 2009, 11:46 AM
RoverC
Cliff
1997 D90 ST
what aux fuel tank are you running?
does that just refill the main tank?
thanks
Old May 26th, 2009, 11:51 AM
http://www.defendersource.com/mod/gas.html
90, d90, fuel, ht
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
low mileage 97 D90 on ebay Chris Cox Misc. Chit-Chat 2 November 26th, 2003 07:17 AM
