D90 Heater - Defender Source
Old April 29th, 2013, 10:14 AM
Premoto1
Tyler
1997 D90 SW
D90 Heater
I've recently purchased a '94 D90 and understand the heat output is marginal at best. Any suggestions for a better blower/heater set up or recommendation on an auxiliary unit. The truck doesn't have A/C and I won't mind sweating it out this summer but don't want to be cold in the winter.
Old April 29th, 2013, 10:28 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
There is a running thread on this which I think is in the small projects section. One way is to open the hole in the bulkhead more to increase the amount of air coming into the dash. Another is to place a stronger motor in place of the factory one.
At the end of the thread that I mentioned one of the guys (if I understood correctly) seems to have found that if you increase the size of the wires that the fan blows stronger, something to due with ohms and resistance.
Old April 29th, 2013, 11:17 AM
The stocker heaters are fine, certainly for Cincinnati. They need a tune up every now and then to get them working. If you don't mind a bit of fab work, better ones can be added fairly easily.
Old April 29th, 2013, 12:45 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Heat has never been an issue in my truck. Can't say the same about the opposite. One way to make airflow more from the heater is to put an intake in place of the grill on the passenger side wingtop. Creates a bit of a ram air effect and definitely increases the volume of air.
Old April 29th, 2013, 06:01 PM
roads
mike
1998 Defender CSW, 1963 series 2a
The heaters on defenders are cable operated and sometimes the Outer sleeve and inner cable can get jammed, gummed up, which doesnít allow the internal flap to operate properly, if you can get some release oil into the cable and work it in it might help.
Check the pipes to the heater, if one is warm or hot and the other is cold your matrix might be blocked, your matrix just needs to be flushed out.
Next thing to check is your cable set up correct, remove the cable at the heater end itís the one on the top, check if the internal flap is moving O.K, get your engine warm and switch on your heater fan, turn by hand the flap control and check if its blowing hot or cold and set your cable, just make sure the flap control is fully open or closed.
I hope that helps.
d90, heater
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
