D90 hard to start - Defender Source
Old June 25th, 2014, 12:44 PM
wesley0620
Wesley Everett
1994 Defender 90
D90 hard to start
I have replaced fuel pump and filter,plugs, wires, cap, and rotor, thermistor on my 94 D90.I have also cleaned IAVC still very hard to start cold and plugs are black when I remove them. Truck runs fine after it does crank but will not start unless you hold the throttle 1/2 to 3/4 down in the morning when you first crank it. Any help?
Old June 25th, 2014, 01:22 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
weak spark or weak battery? check your voltage on the battery, how is your coil? take a plug out and see how blue your spark is
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old June 25th, 2014, 03:37 PM
wesley0620
Wesley Everett
1994 Defender 90
Oh yeah new coil also, spark at plugs looks yellow to me
------ Follow up post added June 25th, 2014 01:42 PM ------
Battery has 12.7 volts spins motor great.
90, d90, start
hard start / rough idle after, mostly during wet condition corrumpu Defender Technical Discussions 2 August 20th, 2012 11:21 AM
Start no start leastonce Defender Technical Discussions 10 February 25th, 2012 02:33 PM
Sudden Stall Then Hard Start artpeck Defender Technical Discussions 11 January 16th, 2010 10:38 PM
Occasional Hard To Start and Now The Engine Spontaneously Dies artpeck Defender Technical Discussions 3 June 23rd, 2009 09:49 PM
easy to start/hard to keep running hamiamham Defender Technical Discussions 0 July 7th, 2008 10:19 AM
