D90 gas tank hole fix - Defender Source
Old August 10th, 2008, 02:11 PM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
Well, I always wondered why my D90 had an odor of gas when the tank was full. The bonehead who owned it before drilled holes in the bed to put a bunch of stereo equipment. While prepping the bed for Rhino liner, I found that one of the drill holes goes into the top of the gas tank. Fortunately, the hole is less than 1cm in diameter. The tank costs over $900 on Rovers North and can't find one elsewhere listed (for now).
Anyone have any good ideas on how to safely patch this hole?
My initial thought was to drop the tank, empty it (b/c probably has dirt from the hole inside), replace the fuel filter and maybe the pump while it is down. Maybe use the fireproof caulk like you would use on the exhaust vent for gas water heaters and the like to patch the small hole?
Thanks in advance,
Heston
Heston
Old August 10th, 2008, 02:36 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
If you have the tank out and the hole is in the top, you could use an 8 or 10 mm bolt/nut/rubber washers
Old August 10th, 2008, 03:31 PM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
Thought about that but was worried that over time, the gasoline might break down the rubber washers? Maybe not -- just trying to get any and all input on the best seal with resistance to breakdown and fire hazards. Thanks much for the input and any follow-up thoughts.
Heston
Old August 10th, 2008, 05:06 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
It's a non structural and non dependent portion of the tank, you just don't want it to leak or crack. The tanks are expensive. Eastwood Company sells plastic repair kits, but the good ones are expensive also.
Old August 10th, 2008, 05:58 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Use a blow torch and weld the plastic back together.
Old August 10th, 2008, 06:41 PM
What he said.
Old August 10th, 2008, 06:55 PM
dkjbama
Derek Johnson
'97 D90ST - Lil' Mule
JB weld perhaps?
Open flames around the tank are a big no-no unless you fill the tank with water to displace all the gas fumes. Those fumes don't just go poof, they go boom.
Lil' Mule - 1997 D90 ST Monza Red #1254
Old August 10th, 2008, 07:08 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Marine-tex epoxy will survive no problem, Dad used it on the steel tank of a Chevy Blazer once, right in the middle of the bottom of the tank. Last I saw the truck it was 15 years later and the patch was still there.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 10th, 2008, 08:13 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
2X on Marine-Tex. Impervious to gas, diesel, solvents, etc.
Old August 10th, 2008, 08:39 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
POR 15 has some good repair kits, and some stuff for gas tanks as well...
http://www.por15.com/products.asp?dept=12
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old August 10th, 2008, 08:57 PM
The POR 15 stuff is all for metal tanks BTW.
Old August 10th, 2008, 09:10 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
This was a joke by the way
Old August 10th, 2008, 09:13 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
He can't answer you, he's at the Burn Unit!
Old August 10th, 2008, 09:33 PM
I'd use the blow torch on the PO...
Old August 10th, 2008, 10:26 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
what you can use ...
How about some aviation type fuel tank sealer (aka PRC). It's a two part mix and holds very well and inexpensive. Combined with a plastic plug, your gas tank will be long gone before this plug ever fails.
My 02 cents.
Pat
Kirk Lazarus, Tropic Thunder
Old August 10th, 2008, 11:27 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
Just use some black duct tape! just kidding...
Marine Tex is the best - it is made for this kind of task.... just prep the tank... scuff up the area where you are going to apply the epoxy with some sand paper - then hit it with some alcohol for a final cleaning before you apply. Good luck... How does the stereo sound... ?
Old August 11th, 2008, 09:46 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Super seal all. Cheap can be found in auto parts stores and doesn't have any issues with gas or oil.
Jimmy Buffett
Old August 12th, 2008, 07:46 AM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
Thanks much for most of the replies! I started stocking up on Silvadene cream, gauze and bottles of saline until someone thankfully told me the blowtorch idea was indeed dicey. I think that I will go with the Marine tex fix. Off to West Marine...
Heston
Old August 12th, 2008, 12:36 PM
I would cut a little piece of stainless steel in a circle, JB weld os similar it to the tank and secure with a few stainless sheet metal screws.
Old August 12th, 2008, 01:13 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Definitely one of the funniest threads on this site in a while.
I had the same thing happen to mine and I used the plastic fuel tank repair stuff from Autozone 3 yrs ago. No problems since.
90, d90, gas, gas tank
Rover Rust hole, not mine, nor do I know the owner. But if you need one. rgrrvr The Flea Market 6 May 28th, 2008 10:52 PM
Condensation in gas tank Antonios Defender Technical Discussions 25 March 25th, 2006 09:38 PM
WTB: NAS 90 rear gas tank headdamage Wanted 11 March 8th, 2005 02:46 AM
