D90 front drive shaft - Defender Source
Old August 16th, 2012, 01:16 PM
dameek
Dennis Meek
95 D90 #2826 Bought New
I have installed new u-joints on the front drive shaft of my 95 D90. When removing it from the vehicle the drive shaft separated at the splines. I know that it was positioned such that the ends were a few degrees apart. But for the life of me I can't get the front of the drive shaft to slide onto the splines. I removed the zerk fitting from the shaft thinking that it wouldn't slide on due to trapped air but that isn't the case. What am I doing wrong? Any help would be greatly appreaciated.
Old August 16th, 2012, 01:51 PM
dameek
Dennis Meek
Fixed
I could see that the male splines have a coating of some kind that had started to peel back from the end of the spines. I used fine grit sand paper and lightly buffed the end of each spline and cleaned up the groves. I could identify the proper mating of the shaft, as the female end has a journal for grease, and the two splines that it straddles, on the male end, had a build of grease reside in one grove. After a light sanding on the end and careful cleaning of the grooves it slid together very easily.
90, d90
Front Drive Shaft ron Wanted 5 July 1st, 2006 08:54 PM
Wanted: Stock Front Bumper for '97 D90 david_jackson Wanted 4 September 28th, 2004 08:06 PM
D90 ARB front bumper w/ winch mount taoseno For Sale - Parts 0 August 10th, 2004 01:41 PM
D90 Front Bumper on ebay nickt For Sale - Parts 0 March 28th, 2004 06:43 PM
Drive Shaft Angles TDI Guy Defender Technical Discussions 27 March 17th, 2004 06:10 PM
