D90 front calipers on RRC - different caliper bolt threads - Defender Source
Old September 19th, 2015, 06:02 PM
On my EV I am running axles from a 1993 RRC, but am putting on D90 brakes. On there front the RRC brakes use a M12 1.25 thread bolt, but the D90 calipers use a bolt with a larger shoulder and 1/2 -13 course thread.
Has anyone run into this and what's the proper solution? I'm assuming it's a 1/2" bolt with a M12 1.25 thread on it, or I need to drill and tap my hubs to 1/2 -13 which I"m not keen on doing.
tia
charles
Originally Posted by pendy
I'm here for the D's
Old September 20th, 2015, 09:46 PM
bump. Anyone?
Old September 20th, 2015, 09:59 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Can't you just swap the knuckles? I don't see an issue with drilling and taping?
Old September 20th, 2015, 10:08 PM
There is not a lot of clearance to get a drill in from behind when installed, although I guess I could pull the hub/rotor and go from the outside in (I can't recall if these are through holes on ears or not). Of course I have already filled the housings with one shot grease!
And of course swapping knuckles is more time and cost too. Reading this I sound lazy. LOL
Would sleeving the bolts be dumb?
Old September 26th, 2015, 06:40 PM
Yeah I just tapped the threads in the knuckles. I don't see an issue with it either. I had to do the rears too.
However now I need bolts and the bolts I have are too long in the shoulder. I guess I need to determine if they need big washers (like > 1/8") or I need to buy something different. Hopefully with the same thread
Old November 15th, 2015, 04:13 PM
I can't seem to win with this one. I got the right length bolts but they are m12x1.25!
90, d90
LR seat belt bolt threads pitchrollyaw Defender Technical Discussions 3 March 3rd, 2015 10:10 AM
LR Caliper for RRC Art Wanted 2 May 27th, 2011 11:21 AM
FYI.. D90 Front Calipers have been rev'd with new parts rlynch356 Defender Technical Discussions 2 May 9th, 2011 10:15 PM
brake caliper bolt problem WhiteD90 Defender Technical Discussions 24 April 29th, 2008 11:10 AM
D90 Front Caliper Hardware source? Antichrist Defender Technical Discussions 3 March 18th, 2008 05:18 AM
