D90 front axle question - Defender Source
Old October 19th, 2011, 09:58 PM
jimmybuffett's Avatar
jimmybuffett
Tom
Hell On Wheels....
quick question.......I am able to swap a entire front axle (front rear) from a D1 into a D90 ? Thanks much!
Old October 20th, 2011, 04:42 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Yes, you can swap them over.
However...... you may need to swap the brakes over, as one or the other may/may not have vented discs.
If it's an early D1, it'll have the 10 spline diff and the large drive member. CV strength may not be as strong as the current one in your d90.
you'll also have to swap the steering rods over, as the disco has the damper mounted low down between the track rod and the diff, whereas the d90 has it fixed up onto the chassis.
Old October 20th, 2011, 10:19 AM
jimmybuffett
Tom
Hell On Wheels....
Thanks the D1
------ Follow up post added October 20th, 2011 08:20 AM ------
Thanks the D1 that i will be getting the parts from is a 1999, so hopefully it will the same ratio, thanks again
Old October 20th, 2011, 11:14 AM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Can you swap just the axle housings from a Disco and use all the internals, brakes, and other parts from the D90?
Old October 20th, 2011, 11:52 AM
What year is your D90?
There are a couple differences. Discos use different steering links including a different drop arm (no big deal, keep the D90 stuff) and discos use non-vented rotors and narrower calipers whereas NAS D90s have vented. Finally, discos have ABS whereas 94/95 D90s do not have that provision (97 D90s do but don't use it for ABS).
If you are talking early 90s pre-NAS, some did not have front sway bars, had narrower radius arms, different hubs etc., but as long as you take the whole assembly including the radius arms off the disco, you should be fine.
Old October 20th, 2011, 02:42 PM
jimmybuffett
Tom
Hell On Wheels....
My D90 is a 94 and the D1 that the front rear is comimg from is a 1999..Thanks
Old October 20th, 2011, 03:34 PM
Keep the D90 brakes and rotors and the D90 steering and you should be fine. You will need to leave the wheel speed sensor on the disco axle, but just cut the wires.
Old October 21st, 2011, 11:02 AM
jimmybuffett
Tom
Hell On Wheels....
Thanks to all --
90, axle, d90, front axle
White 94 D90 for $15,000 Tom B For Sale - Vehicles 14 December 7th, 2005 12:19 AM
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
D90 Front Bumper on ebay nickt For Sale - Parts 0 March 28th, 2004 06:43 PM
