D90 Engine Overhaul - Defender Source
Old March 29th, 2004, 10:39 AM
Landyfun1
Bart Buckethal
D90 Engine Overhaul
Hello. I am a long time Series truck owner getting ready to purchase my first D90 and had a question about engine overhauls. Most of the Series vehicles I have owned over the years at one point or another have needed an engine overhaul. However given that they were all very simple 4 cylinder trucks it was easy and relatively inexpensive.
One of my main concerns with moving into a Defender is having the engine overhauled. Most of the 94/95 year D90’s out there now have some years and mileage on them. What can someone expect to pay to have the 3.9/4.0 re-built? (Or replaced depending) Are there any companies in the US that do this type of work?
Any insight would be greatly appreciated!
Old March 29th, 2004, 11:14 AM
jstrong98's Avatar
jstrong98
Jon Strong
check east coast rovers, they do all kinds of engine overhauls.
I think they will put a disco engine in also.
http://www.eastcoastrover.com/
Old March 29th, 2004, 11:34 AM
I think it would be as easy to get your motor repaired/replace/overhauled as it would be for just about any other automobil.
Old March 29th, 2004, 11:42 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
If your lucky it will be years before that is something you will have to do. I have 140k on my Disco and no problems, just oil changes and routine stuff. I have had a few series trucks also andd there was always somthing to work on or needed to be fixed, thats just the nature of the beast of owning a car that old. Find a 90 that has good service records or find one that already had an overhaul.
Old March 29th, 2004, 12:28 PM
Landyfun1
Bart Buckethal
Good call on East Coast Rover. It looks like they are a one stop shop with regard to major Rover repairs.
I am hoping to get a few years out of the truck before MOH however I do want to know exactly what I am in for before I make the step. And it is very fair to point out that all Rovers need little things now and again! My 1971 109 needs a little TLC every weekend.
Old March 29th, 2004, 12:49 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Bart,
Just be aware that East Coast Rover will be very expensive. Phil hit it on the head. Find a good local engine builder. Blocks run around 1400 USD for a 4.0 I saw Rovers Down South had a few of them.
EwS
Old March 29th, 2004, 02:04 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I'm having West Coast British buy and referbish a 4.2 for me (220 hp stock) with high performance cam, new lifters, rockers and mains, for around $3500 to $3700. I'll then sell my 3.9. Anyone interested in the 3.9? Runs good but probably suffers from a flat camshaft (power fades at higher rpm). 100K miles.
DW
Old March 29th, 2004, 02:46 PM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
Doug, I'm curious. Why not a 4.6 or 5.2 since you're replacing the block anyway?
Arthur M Vigil
Colorado Native
Former owner of:
'95 RRC - 3.9V8 Rimmer Supercharged!
'72 Series III 88" NADA Turner 2.25 petrol (Lovely Rita)
'95 RRC Brooklands/TWR Edition 3.9V8
'97 D90SW NAS #2426 - 3.9V8 Rimmer Supercharged!
'95 D90ST NAS#2620 - Original owner
Old March 29th, 2004, 03:07 PM
Doug's Avatar
Doug
Doug Walker
The 4.2 makes 10% more hp than the 4.6 stock (220 vs. 200), and the 4.2 is 100% plug and play with the 110's ignition, fuel and electronics which = saved $$. I'm more interested in improving top end hp than low-end torque which seems sufficient even on my 3.9. Also, a used 4.2 is considerably less money than a 4.6.
I figure I'll be at about 245 hp when the mods are done, which should be totally adequate for my needs. Don't know much about the 5.2.
DW
Old March 29th, 2004, 03:12 PM
Treasured motor cars in owings mills can help you.
If you change the oil frequently and the coolant every 30k or two years you should be fine with the 3.9 for a long time.
Ron
Old March 29th, 2004, 03:59 PM
pangaea's Avatar
pangaea
Nathan Hindman
95 Discovery, D130
Bart,
If you get your 3.9 (or 4.0) rebuilt, you'll have at least $1200-1500 into it for new gaskets, rings, bearings, machine work etc. Why not spend a few extra bucks for a big upgrade?
When time comes for the engine swap, give the guys over at Rover Tracks... sorry, RT Designs a call. Keith is in the process of designing a 4.8 upgrade that should cost between $2K and 2,500. It should be plug and play with the standard Rover set up, but with a bunch more power....
Nathan Hindman
http://www.pangaea-expeditions.com
Old March 29th, 2004, 04:30 PM
Landyfun1
Bart Buckethal
Pangaea:
Where is RT Designs located? I did a search online and couldn’t find them?
Ron:
I have not dealt with Treasured Motor cars; however Owings Mills is really close. Do they specialize in British stuff? I also have a MINI that I am needing work on.
Old March 29th, 2004, 05:09 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
Ron:
Bart,
RT Designs (a.k.a. Rover Tracks ) is based in CO. I believe the owner is Keith, also a member of this community.
Treasured Motor Cars is owned by Trevor Griffiths, another member of this community. As far as I know, they only worked on Rovers but I could be wrong. I'm sure if they can work on rovers, your mini wouldn't be to "big" of an issue
Good luck!
Glenn
Old March 29th, 2004, 05:24 PM
Not sure if TMS does mini, the rover is sort of the low end for them. They are a ferrari, lambo, jag place mainly.
Ron
Old March 29th, 2004, 07:00 PM
pangaea's Avatar
pangaea
Nathan Hindman
95 Discovery, D130
Bart,
There here in Colorado. Check 'em out at:
http://www.rovertracks.com
nathan
Nathan Hindman
Old March 30th, 2004, 11:59 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
I'm in for the rovertracks upgrade. Been wondering who is going to address this burgeoning market.
Old March 31st, 2004, 12:19 AM
I met him over the weekend, Very COOL guy. He did everything he could to try and help me with my waterpump. They do great work even on Rovers.
Old April 20th, 2004, 03:17 PM
Doug's Avatar
Doug
Doug Walker
Just FYI. The 4.2 project was scrapped in favor of a brand-new modified 5.0 generating 340hp and about 350ft/lbs torque. Hope the rest of the truck can stand it! More news in a few weeks after the install is done.
DW
Old April 20th, 2004, 03:35 PM
SWEET! You will be breaking Rover drive line in no time!
Old April 20th, 2004, 06:02 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Treasured Motorcars does excellent work on a variety of cars, certainly rovers, but they are true enthusiasts and I'm sure would contemplate a Mini. Failing them, drop me a note and I can get you in touch with some other local mini enthusiasts.
Best,
Tony
90, d90, engine
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Need help with D90 engine problem Chris Cox Defender Technical Discussions 3 January 10th, 2004 08:41 PM
