D90 cold start problems - Defender Source
Old November 18th, 2012, 06:46 PM
aquamanaquaman
Mark
1995 D90
Anyone experience this?
My D90 seems like it does not get the right air /fuel mixture on occasion when starting cold.
When this happens, it will be VERY hard to start and once running, will have very little power.
Once hot, it cleans out and runs fine.
It starts hot quite easily and even starts most times cold quite easily with a high idle for a little while.
What is the most likely suspect -- a temp sensor?
And help would be appreciated.
Old November 18th, 2012, 08:08 PM
There are 2 temp sensors on a D90. One for the gauge and one for the ecu. If there is a problem with the coolant sensor the ecu uses a 'default' value which allows the truck to limp home.
Sounds to me that either the coolant sensor is disconnected or is faulty.
Old November 19th, 2012, 12:35 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
When cold, what happens if you drive up 20-30mph and put it in neutral (while moving)?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old November 25th, 2012, 05:03 PM
aquamanaquaman
Mark
1995 D90
Thanks for the feedback. That was my thought s well. When cold, most often it will run properly (i.e. idle at high idle in neutral). When the issue arises, it will die when cold when coasting.
90, d90, problems, start
Well Equipped Red Soft Top '97 D90 for Sale - Priced to move fast! muskatd For Sale - Vehicles 11 May 31st, 2014 09:07 PM
1994 D90 Wont Start ! jimmybuffett Defender Technical Discussions 16 June 8th, 2012 03:25 PM
'95 D90 3.9L missing for 10' after start... HMB_Defender Defender Technical Discussions 2 August 7th, 2011 04:10 PM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
» Defender Registry
RAF
Realm
D90 #2326
DM2326
Add your Defender
