D90 Clutch pedal tightness - Defender Source
Old April 17th, 2015, 09:21 AM
ssi19's Avatar
ssi19
scott
1995/D90
My left leg is getting a serious workout. Has anyone had any luck reducing the tension on the clutch pedal? As simple as replacing the spring?
Old April 17th, 2015, 09:40 AM
I'm making the assumption that there is something wrong with clutch as my 95lb wife doesn't complain about this ...
Have you tried disconnecting the spring and seeing how easily it goes down? That should be the first step. If it's hard to depress the clutch then you need to get it looked at.
If it operates smoothly then perhaps some spinach and a few sessions at NYSC?
Old April 20th, 2015, 09:06 PM
ssi19's Avatar
ssi19
scott
1995/D90
Any other ideas (besides taking roids - thanks Jason).
Old April 20th, 2015, 09:18 PM
Is it a 95 that you have? It should have the later pedal box which is lighter than the earlier ones. Possibly something is wrong. Is there another truck in the area you can compare to?
Old April 20th, 2015, 10:12 PM
ssi19's Avatar
ssi19
scott
1995/D90
yes- 95. I drove Keith's (Shep's) 90. It was shorter and looser than mine (that's what she said – Ha). But I've had no issues with my clutch slipping in the almost 4 yrs I've owned my truck. It performs great. It's just a lot of effort. Any ideas?
CDeWan
Clay DeWan
5.3L beastie
is this under normal driving or is this an "i am stuck in a commute and my leg is killing me" from upshifting and down shifting? Has this always been a problem or did it begin in a measurable length of time?
Old April 20th, 2015, 10:16 PM
ssi19's Avatar
ssi19
scott
1995/D90
Always a problem as long as I have owned her. I wouldn't consider it a "major" problem. Just curious if anyone has dealt with it, and found a solution to modify for the better. Thanks all.
Old April 20th, 2015, 11:08 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Fit a td5 clutch pedal assy, as it has the over Centre spring (breakover) rebuild the master and slave cylinders, adjust pedal height. Your cylinder rubbers could also be swollen if the fluid has not been flushed in some time.
I have a rebuild left knee and do not any problems, unless stuck in Houston traffic.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 20th, 2015, 11:27 PM
I thought the over center pedal box came out in 1994 with the 300TDI and so his truck should have it.
Old April 20th, 2015, 11:30 PM
If it is truly heavy and you have the later style pedal box, then I would first check that there is not a problem in the hydraulics. If not there, then maybe you have a heavy duty pressure plate or something.
Old April 21st, 2015, 12:13 AM
roverman2010
1985 LR 90 200Tdi
I have a HD diesel clutch assy in mine with the Td5 peddle box and it's really a easy push, the over Centre spring came out in 300tdi/td5 not sure of the years but wasn't it after 95????
While typing this somebody had broken into the house next door, of what a fun night, guess who has to board it up now
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
WTB Clutch pedal assembly for 94 D90 Broncoduecer Wanted 1 February 2nd, 2011 08:30 PM
Clutch pedal to floor MARKGOLDSMITH Defender Technical Discussions 6 October 30th, 2006 06:18 AM
Clutch Pedal Sticking whitelandy Defender Technical Discussions 8 October 8th, 2004 10:23 AM
Clutch Pedal Rubber Dfndr90 Defender Technical Discussions 9 September 2nd, 2004 12:00 AM
Sticky Clutch Pedal JimC Defender Technical Discussions 11 March 11th, 2004 01:44 PM
