D90 caliper brake pin - cotter pin help - Defender Source
Old May 28th, 2009, 03:57 PM
Gardrover
James
95'
The retaining pins on my D90 calipers rattle like hell and its getting really annoying,
i think the cotter pins that retain the retaining pins are the source of my angst...
Does anyone have a cotter pin size they know offhand that fits and helps control the rattle??
Its driving me insane
Old May 28th, 2009, 06:46 PM
Dont the front supposed to have springs and the rears have 2 little metal clips per side? I am assuming you are talking about brake pads.
Old May 28th, 2009, 06:48 PM
what I want to konw is how you KNOW that is the source of the noise??
Old May 28th, 2009, 08:10 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I don't think there is any way in the world that the little brake pad retaining pins (which are held under sprung tension)could ever make enouh noise to be heard over road and engine noise.
Old May 29th, 2009, 02:01 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
It can't be those pins or the metal retaining clips. unless you have superman's hearing. If they are loose and rattling then you have a very strange issue. how can the brake pad stay firm in the caliper when you brake and unbrake and have the retaining clips and pins jiggling around? sounds odd so I don't think thats your problem.
Check all the nuts and bolts under the truck. one of those might be loose instead.
90, brake, d90
Brake options - what would you do in a pinch? cgalpin Defender Technical Discussions 7 April 9th, 2008 08:20 AM
Range Rover Front Brake Caliper Question TDI Guy Misc. Chit-Chat 10 May 24th, 2006 08:14 PM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
