D90 bumper on a D110? - Defender Source
Old July 2nd, 2004, 01:08 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Does this look like a safe mount to you guys?
ID:	970   Click image for larger version
Old July 2nd, 2004, 01:15 PM
Hmmm took me a second to figure out the pic but, You are going to use 2 bolts on each side correct? And what size are the bolts?
Old July 2nd, 2004, 02:29 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
The stock bolts from the original bumper. The holes line up but the 90 bumper looks like it should be 1/4 inch further back.? Is that a problem? I will also have to cut the bump out for the grill. [ grill extension ]
Old July 2nd, 2004, 02:37 PM
Looks to be OK, I think the most you would have to worry about is if you were pulling sideways with a winch, but even then you would still be only adding a small amount of stress in addition to what is already there. My ARB has another bolt across the bottom going through the frame (perpendicular to the stock bolts) you could drill and add it as an extra support.
110, 90, bumper, d110, d90
94 D90 or 93 D110 Bumper Someone...Anyone... bitz Wanted 4 June 16th, 2008 04:26 PM
Rockware bumper for D90 Shane@EVS For Sale - Parts 16 April 5th, 2006 01:16 AM
D90 and D110 lower sills Method PHX For Sale - Parts 0 December 8th, 2005 11:39 PM
D90 ARB front bumper w/ winch mount taoseno For Sale - Parts 17 October 14th, 2004 11:32 AM
D90 ARB front bumper w/ winch mount taoseno For Sale - Parts 0 August 10th, 2004 01:41 PM
