d90 bogging & hesitating off idle - Defender Source
Old April 6th, 2004, 02:26 PM
vesparover's Avatar
vesparover
brian bertolini
Hey everyone, my truck started bogging off idle at a stop light today. I'm having to rev it to a couple grand to keep it from lurching. It seems fine at the higher revs though- but when starting the truck I have to give it gas. If I push the pedal to the floor it will bog down. Anyone have any experience with this? There are no fault codes.
thanks
brian bertolini
Old April 6th, 2004, 02:44 PM
Check your spark-plug connections at both ends of the wires.
Old April 7th, 2004, 10:10 AM
vesparover's Avatar
vesparover
brian bertolini
Alright now it won't start! It sounds like it wants to catch here and there but won't fire up. Any ideas now?
thanks
brian bertolini
Old April 7th, 2004, 10:41 AM
So, the starter spins and you can get the motor to crank at least 120 rpm.
Have you checked for spark?
And are you getting fuel?
Old April 7th, 2004, 11:21 AM
vesparover's Avatar
vesparover
brian bertolini
I'm gonna get cracking on it in a few hours- try to get an idea of what's wrong with it this time.
Thanks mike
brian
Old April 7th, 2004, 11:28 AM
Cool, let us know what you find, I just did some searching on the subject ( to try and help) and found allot of unresolved threads.
Old April 8th, 2004, 03:16 PM
Dflyhawks
Donald/Hawks
1994/Defender 90
I had a similar problem. Turned out my distributor had moved less than a quarter inch. I used a timing light to fix the problem. Find the mark for 5 deg. BTDC on the bell housing, connect the timing light, turn engine on and turned distributor until 5 deg. mark and the mark on the block line up. This worked for me. Could also be a bad distributor cap or rotor, check both of these.
Donnie Hawks
Old April 8th, 2004, 06:49 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Also check out your vacuum advance hose.
Old April 8th, 2004, 06:57 PM
vesparover's Avatar
vesparover
brian bertolini
I'm wondering if it is distributer related. How do I check the vac advance? The hose appears to be good with no leaks when I hold one end closed I can feel the suction from the plenum. Does this sound like an air gap issue? Other than changing the cap and rotor I don't know how to work on a distributor- or I have never worked on one in the past. Another thing is that I hear a whistling noise coming from the rear of the engine. It's definately not a belt- and it has become worse over the past couple of months. Now it's getting to the point where it doesn't want to start at all. I could really use some help with this pos. I don't trust any mechanic down here anyway- and other than the dealer there is only one. There appears to be sufficient fuel pressure but I haven't pressure tested it as of yet.
thanks
brian
Old April 8th, 2004, 07:55 PM
wicks's Avatar
wicks
Wicks
The distributor is rotated to establish the spark timing in relation to the cylinder movement. It can be advanced and retarded to establish different explosion management and so forth. I have a disti-less 97 motor, so I haven't had to do much with it.
Get someone to pull that page out of the service book for you...
Old April 9th, 2004, 02:49 PM
vesparover's Avatar
vesparover
brian bertolini
Problem solved
Thanks for the help guys! It ended up being a timing issue- the nut that holds the distributer tight loosened up. The distributer had moved all the way back- retarding the timing. I advanced it and set it.
Brian Bertolini
Old April 9th, 2004, 04:03 PM
wicks's Avatar
wicks
Wicks
Very good Brian. Hawks nailed it.
What d-90.com is all about.
90, d90, idle
High Idle on 97 D90 ndhlp Defender Technical Discussions 3 November 26th, 2006 11:59 AM
1994 D90 Idle "hunts" TonyV Defender Technical Discussions 3 June 1st, 2005 04:47 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
