D90 and Stand Up Paddle Boards (or LongBoard) - Defender Source
Old January 29th, 2012, 06:39 PM
jkins
john
95 Defender 90 - Beluga
Hello All,
I have a 94 D90 Softtop and am getting a couple of Stand Up Paddle Boards. Anyone carrying them on top of their truck w a specific type of roll bar cover/strap? I assume that an 11' board would stick out of the backseat a little far...
Thanks!
Old January 29th, 2012, 06:43 PM
Thule made a set of cross bars specific to the NAS trucks, they are hard to find complete and usually run around $300. Some have adapted a set of cross bars for the Xterra. Not sure what you would do with the back end, maybe one of the hitch mounted Kayak carrier.
Old January 29th, 2012, 07:27 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I make a ton of custom crossbars for surfers, kayakers, and paddle boarders. Here are a few pics. I've done some crazy ones where both crossbars lean backward/forward 45 degrees, and another set with a hoop that went back over the rear cargo area to support a canoe.
ID:	46788   Click image for larger version
Semper Fi!
Old January 29th, 2012, 08:55 PM
jkins
john
Can you give me more info of what it would cost to get one made that is large enough to handle two boards that are 30" to 33" wide?
I like the look of the first picture.
Old January 30th, 2012, 06:35 AM
Wolf Fabrication
Sterling Archer
'08 D3
If you want to be able to put two 33" wide boards side by side, they'll be wider than the roll bar itself. If that's what you want I can build a pair of bars to suit. A pair of custom bars usually run about $400. PM or email me.
Semper Fi!
Old January 30th, 2012, 10:54 AM
sirjond's Avatar
sirjond
Jonny
1995 D90 ST Alpine White
So the bar setup in the first picture (on the white 90) are $400?
Old January 30th, 2012, 11:18 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Joanathan makes a great product and I am in line for a pair of loadbars and a 1/2 rack. He is just too busy having fun painting his rig right now.
Old January 30th, 2012, 11:33 AM
Wolf Fabrication
Sterling Archer
'08 D3
Straight, normal bars are $300 painted black, $375 powdercoated - like the ones on the white D-90. Doing custom bars, like making them wider, slanted, or extend back, usually run about $400.
Semper Fi!
Old January 30th, 2012, 11:35 AM
sirjond's Avatar
sirjond
Jonny
sending pm
Old January 30th, 2012, 12:44 PM
wilyliang's Avatar
wilyliang
Peter
'95 D90 SW #441
Have you invented/fabricated any bar racks with a longer spacing? I've got a SW and have been trying to come up with a way to carry plywood or small amounts of lumber, but I'd need a bar towards the back (gutter mounted?). Any ideas?
One thought was to put some ABS "rollers" on my Brownchurch, but I'm wary of the weight.
Old January 30th, 2012, 01:03 PM
Wolf Fabrication
Sterling Archer
'08 D3
I have. Looking at the truck from above, I've made a crossbar with a U welded to it that goes over the passenger area. It was for a canoe, but the same principle could be used to carry a few sheets of plywood. The only issue is getting up over the back of the truck.
Semper Fi!
Old January 30th, 2012, 04:35 PM
draaronr's Avatar
draaronr
Here
LR3
put the fin to the front though when you take pics and haul around.
Old January 30th, 2012, 07:42 PM
wilyliang's Avatar
wilyliang
Peter
'95 D90 SW #441
Nice! Got any pix? Price?
Old January 30th, 2012, 08:00 PM
jkins
john
What about for two boards (~30") on top of each other?
Old January 30th, 2012, 08:09 PM
specops1526's Avatar
specops1526
Beluga '97 90
I posted a sighting of a guy who has a solution for this:
http://www.defendersource.com/forum/...postcount=2096
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old January 31st, 2012, 01:27 AM
california
Geoff M
that hitch thing is really terrible
I used regular Gutter mounted Thule towers for years from REI. They are not as nice as these custom set ups but they worked perfectly. Mounted behind the roll bars, the clearance was close, and the bars were only 1" off the roof but they worked. Long boards and SUP boards do not really need pads, just strap them to the crossbars.
and get a step ladder, old man style
Old January 31st, 2012, 10:51 AM
Wolf Fabrication
Sterling Archer
'08 D3
Sadly, no pics. I was in a big rush. I made them for Copley for one of his trucks though. I think they were $450 bare steel.
------ Follow up post added January 31st, 2012 10:53 AM ------
That would just be normal crossbars, just stack 'em on top of eachother. $300.
Semper Fi!
Old February 1st, 2012, 12:12 PM
sirjond's Avatar
sirjond
Jonny
Wolf, sent you a pm but haven't heard back.
Old February 1st, 2012, 01:16 PM
Wolf Fabrication
Sterling Archer
'08 D3
My bad. Just replied.
Semper Fi!
Old March 8th, 2012, 11:14 PM
jkins
john
I have my boards ordered and they should be here shortly (two 12 ft Lairds) so now I am back to how to transport them on my D90. Sounds like Wolf has one good solution.
Any others who would be willing to post pictures/share their experience? I want to look at all choices before I drop more cash.
90, d90
