D2 Window regulator install? - Defender Source
Old December 15th, 2009, 12:59 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
I bought this for the driver side front window because even after the $2 fix it was still acting weird. So does anyone have a writeup or advice on how to do this?
Old December 15th, 2009, 07:31 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Do you have the workshop manual ? it should be in it.
- Charles Eames
Old December 15th, 2009, 09:20 AM
JohnsD90's Avatar
JohnsD90
No, I'll PM the person i got directions from last time. Then post it up here.
Old December 15th, 2009, 09:44 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Easy schmeezy:
1. Remove door panel
2. Peel back bottom of plastic vapor barrier tape it to the top of the door
3. Unplug wire from window motor
4. locate hex bolts on door frame (3 on motor, 2 on slide)
5. Remove them
6. The regulator will drop down into the bottom of the door, assist it so it does not go kerplunk
7. locate the hex bolts on either side of the bottom of the window
8. Loosen them, do not remove them
9. slide the bottom bracket on the window till it clears the two bolts.
10. Slide the window back up and have a buddy hold it for you.
11. Remove the regulator from the door frame.
Reverse for installation.
Old December 15th, 2009, 12:36 PM
JohnsD90's Avatar
JohnsD90
Yes! Thanks.
Old December 15th, 2009, 02:22 PM
landrovered
S. Smith
The bolts are shouldered, "hex" might be misleading, they are normal style bolts but shouldered.
window
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
shattered sliding window on d-90 prospector Defender Technical Discussions 5 January 16th, 2005 10:41 PM
Soft Top Side Window Bar boshea Wanted 2 June 18th, 2004 08:14 PM
st driver&passenger window bases fill with water Marc Weinstein Defender Technical Discussions 6 April 15th, 2004 06:52 PM
Window rattle ? Hammertime Defender Technical Discussions 3 April 13th, 2004 04:08 PM
