D2 Auto box? - Defender Source
Old August 27th, 2015, 09:00 AM
Abrooks's Avatar
Abrooks
Tony Brooks
D2 Auto box?
Is a RRC/D1 ZF = D2 ZF? The RRC needs a transmission and it appears that D2 transmissions and lt230s are far easier to source than D1. Beyond the known issues with the ability to shift some D2 LT230s, will the transmission bolt in and play happily with a 4.6 in a rrc?
Old August 27th, 2015, 09:59 AM
Electronics kicked in with obd2 in 1996. Connecting engine and box more than on 95 and prior years.
Old August 27th, 2015, 10:55 AM
The Dro
Dro
1988 Ninety
No, and They will bolt in... But you'll need to get a Compushift (Expensive).
There are three (3) different "flavors" of the ZF 4HP: 4HP22, 4HP22EH and 4HP24EH. All three have the same casing with different components.
The 4HP22 has hydraulic valve body; the 4HP22EH and 4HP24EH have electronic valve body.
The ZF 4HP22, fitted on the RRC and Disco I from 1994 until 1999 (97 Defender too); And the ZF 4HP22EH, fitted to the Disco II with the 4.0L motor (1999 to 2002). The 4HP24EH was fitted on the 4.6L Disco II (2003 and 2004). Don't ask me about the P38 beacuse I don't care about them.... But probably is the same shit (4HP22EH on the 4.0L and 4HP24EH on the 4.6L).
The good news is that you can fit all the 4HP24EH components on a 4HP22.
No... The RRC, Disco I and 97 D90 have hydraulic valve body.
Old August 27th, 2015, 02:07 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I have a tranny out of a 1995 Disco if you need one..
good luck with your search
LT 230 SHift Lever Assy (Auto Box) jetmech Wanted 0 January 30th, 2010 08:00 PM
'97 Auto Box shift bezel Viton Defender Technical Discussions 4 February 25th, 2009 11:59 AM
300 TDI w Auto Gear box / Transfer Case SafariHP For Sale - Parts 0 January 2nd, 2007 09:23 PM
ZF Auto box, works $150.00 RedRhinoProducts For Sale - Parts 1 October 17th, 2004 10:44 PM
3rd - Detroit Locker 4.10, Auto Trans, Steering Box, ABS Pump mudrover For Sale - Parts 2 August 9th, 2004 12:25 PM
