D110 Wheel question - Defender Source
Old November 18th, 2009, 08:09 AM
disco dog's Avatar
disco dog
Tracy Dwyer
2002 D110 TD5
D110 Wheel question
Does anyone know if the wheels from a NAS D90 or D1 will fit on a 110 TD5? The axle's on a TD5 are fatter then on a tdi and the hub nut tool is also larger, making me think that the lug pattern my not work. Anyone know for sure? Thanks in advance.
Tracy
PURA VIDA !!
Old November 18th, 2009, 08:34 AM
There are some varying stud-lengths depending on what wheels were originally on it, but all defenders and d1s have 5 on 6.5 bolt pattern and the wheels should bolt up. Alloys from newer trucks won't necessarily fit properly on older axles for other reasons.
Old November 18th, 2009, 11:51 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Yup, what Jim says.... all defender/90/110/130 and series 1,2 and 3, right up to the current Puma steel wheels will fit each other.
The HD "wolf" vented steel wheel is slightly thicker than the rest, but if you buy the LR "extended wheel stud", it's the same length as the alloy wheel type studs (which are identifyable by having a "-" stamped across the end of the stud)
300Tdi, Td5, puma and late 200Tdi axles are capable of fitting alloys, you can tell by a) the "-" stamped in the stud as above, and b) they'll have the thinner drive flange and small rubber end cap.
Old November 18th, 2009, 03:49 PM
winn442's Avatar
winn442
Winn Bearden
I had a 110 Td5 several years ago...it came with tube-type steel wheels.....replaced them with some Deep Dish alloys with no problem....the older 110's, can't remember the year change, couldn't wear alloys...had an older 110 that I was dying to put alloys on and I had a machine shop lathe out the alloys to make them fit.
Winn Bearden
Old November 18th, 2009, 04:58 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Originally Posted by winn442
the older 110's, can't remember the year change, .
Mid 1992, when they introduced disc braked rear axles.
Old November 19th, 2009, 04:40 PM
disco dog's Avatar
disco dog
Tracy Dwyer
2002 D110 TD5
As always, thanks for the help!!
PURA VIDA !!
110, d110, wheel
D110 question disco dog Misc. Chit-Chat 2 September 24th, 2009 12:26 PM
D110 Hubcentric wheel spacers kingstonman Wanted 0 June 10th, 2009 05:49 PM
New D110 owner question BEIS Defender Technical Discussions 8 October 29th, 2008 09:52 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
