D110 Trans issue - Defender Source
Old May 31st, 2016, 06:14 PM
Johna56
john
none
D110 Trans issue
I bought an '86 D110 ex-mood with 2.5 Diesel LT77/230 a few months ago. I'm having my first real mechanical issue. I think I've narrowed it down but am requesting opinions.
The first time this happened, the tcase shifter jumped out of gear at a light as I was slowing down and then locked into 2wd lo. I suspect that I caused the tcase to lock up with my overzealous attempt to get the vehicle moving again because the mechanic did say he adjusted the linkages.
After driving the vehicle for about 15/20 minutes, it slides out of gear and will not go back in for awhile. The time that passes before it will engage again varies. Diesel mechanic confirmed the linkage are fine.
This has happened several times since the first time, but now it slides out of gear silently and will not re-engage until a period of time has passed. The period of time varies. When this happens, without depressing the clutch pedal, I am able to freely move the transfer case and the gearbox shifter all around with out grinding or engaging any gears in any way. 5-15 minutes will pass before I am able to engage the gearing.
I have some thoughts on this (slave cylinder, throw-out bearing) but would like to know if anyone else has experienced anything similar with their defenders and what they think the issue is.
Thank you in advance for your time.
Old May 31st, 2016, 06:49 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Think what you are saying that the T-case jumped out of gear and you got it back in which is normal as this often happens after shifting when it is not all the way in.
I also think you have switched subjects to then indicate that in additional you are having shifting issues with the LT77, basically it goes out OK, but doesn't want to go in gear.
If so, this is most likely a clutch issue.
You might remedy it by adjusting the clutch rod at the clutch master cylinder or replacing the clutch hydraulics.
If some knucklehead filled the LT77 5 speed with 90 weight or ATF instead of MTF94 this shifting difficulty can also happen.
The "high performance" of the 2.5 coupled with shifting issues has to be dangerous to drive.
I once pulled out on the highway with a 2.5 N/A and a car 5 miles back nearly ran into the back of me.
RDavisinVA
Old May 31st, 2016, 08:29 PM
Johna56
john
none
Yes. Potentially 2 issues. I need to figure out how to segregate and fix each issue or who to bring it to that can.
Old May 31st, 2016, 08:38 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I don't think there is a transfer case issue.
There is a member on Long Is, NY that can sort your issues in his shop.
I can dig up his contact info if needed.
RDavisinVA
Old May 31st, 2016, 09:09 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
I just want to clear up something you said above. All Defenders (all Land Rovers?) are 100% full time four wheel drive. The only way to make your Defender two wheel drive is to remove one of the driveshafts. (Which can be done, but makes drive oddly.)
Your Defender has 4WD high, 4WD low, and you can lock the "center diff" in both high and low.
Defenders draw attention. Don't buy one if you're shy!
Old May 31st, 2016, 09:47 PM
Johna56
john
none
rdavisinva, thank you. If you can forward the contact info i would appreciate it.
GuamPilot - Mike, Thanks for the clarification. After you wrote it, I recalled reading that someplace but its been a lot of reading and info so I know its going to take some time to retain it all. Is it correct to say the lt230 has 2wd high, 4wd lo, and then a "locked" 4wd high and 4wd lo? Thanks.
Old May 31st, 2016, 09:58 PM
The LT230 has 4 modes: 4wd high, 4wd low, locked 4wd high, locked 4wd low.
There may have been some rare 2wd LT230s but you definitely do not have one.
Old May 31st, 2016, 10:28 PM
Johna56
john
none
Understood, I typing 2wd was an error. Thanks.
Old June 1st, 2016, 01:51 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Guy's name is Chris.
His handle is rovertek on this forum.
RDavisinVA
Old June 1st, 2016, 04:53 PM
Johna56
john
none
Thank you.
110, d110
Battery Issue or Charging Issue? icnsltmfg Defender Technical Discussions 4 May 19th, 2016 01:25 PM
NAS D110 Transmission Filter (Auto Trans) ckg Defender Technical Discussions 16 April 25th, 2016 10:13 AM
RRC trans issue, or? Ren Ching Defender Technical Discussions 7 March 31st, 2015 12:43 AM
Radiator? for a 4.2L and Auto Trans into a D110 RhinoRover Smaller Projects 21 February 16th, 2015 02:02 AM
1983 D110...trans/tcase/sals rear brakes mongosd2 Truck Build-up's & Restores 1 January 26th, 2011 12:28 PM
