D110 Front Suspension Install - Defender Source
Old March 14th, 2012, 09:01 PM
D110DC's Avatar
D110DC
Pete
66 SIIA, 70 IIA, 97 D90
Angry D110 Front Suspension Install
OK, basically I'm getting pissed because I know this must be something much more simple than I can realize at this moment. I am rebuilding a 1983 D110 (see Registry), and have finally made some progress in the past couple months after 3 years.
After getting the original front axle lined up, Terra Firma shock turrets installed, mounted the front springs and shocks, and reinstalling the original trailing arms, the shocks/shock towers appear to be "twisting" in their mounts (see pics). When some NAS shorter trailing arms are used, it appears to rectify the issue somewhat, which tells me that either:
1) the axle is "turned"/canted down/up too much, which have affected the spring mounts on the axle, OR
2) the axle is aligned incorrectly from left to right, OR
3) the hell if I know
Any thoughts? Other than some smaller issues, it's about the only issue I have left on my rebuild to get completed.
Pete
ID:	49087   Click image for larger version
ID:	49089   Click image for larger version
ID:	49091   Click image for larger version
ID:	49093   Click image for larger version
Pete
1966 ECR Series IIA
1970 Series IIA (Stella)
1997 D90 ST
2011 LR4 HSE
2010 Range Rover Supercharged
Sadly gone (some more sadly than others):
1983 D110 Double Cab 300 TDi
1989 RRC
1996 D1
2006 LR3
2008 RR
Old March 14th, 2012, 09:49 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
couple questions
1. what is angle of lower spring perches
2. stand height towers?
3. pinion angle?
Looks to me that you need to start measuring angles and lengths. I am going to guess either too much lift or radius arm length is off. You likely need cranked radius arms or a different length arm. Basically the lower perch where the shock mounts is at an angle and or further forward or back from stock.
Old March 14th, 2012, 09:58 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
What spring lift did you use? Did you set the toe to the stock bar length?
Land Rover 110
Old March 18th, 2012, 05:25 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Are you running a lift? Is the Engine in?
If the engine & transmission isn't in then the springs will push the chassis up very high, the tie bar from the chassis to the axle will be running at a much steeper angle than intended and will pull the axle over as a consequence.
Drop the engine in and my bet is it'll sort itself out for you.
Mike Hammond
Old March 18th, 2012, 06:05 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
The terra firma towers have a left and a right in case you weren't aware. Here's what mine look like
ID:	49246   Click image for larger version
Old March 18th, 2012, 07:57 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
I think those are in backwards. I had a set and remember they were NOT universal.
------ Follow up post added March 18th, 2012 06:58 PM ------
What he said!
110, alignment, d110, front axle, front suspension, shock turret
Front suspension set-up needsaD110 Defender Technical Discussions 1 October 25th, 2007 06:49 AM
Front Suspension Buckon37s Misc. Chit-Chat 17 November 27th, 2006 01:02 AM
Front suspension troubleshooting... sflash868 Defender Technical Discussions 1 June 5th, 2006 07:22 AM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
bilst. suspension, tires/wheels, others SeaRover For Sale - Parts 9 May 26th, 2004 12:26 AM
