d1 or d2 seats in a series/ defender - Defender Source
Old October 14th, 2010, 10:58 PM
orionpco
larry burns
1962 series 2a
what would it take to install d1 or d2 seats in a series or defender? would they be to tall?
Old October 14th, 2010, 11:02 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I've seen RRC seats used but not disco. I'm sure someone will pipe up on it.
Old October 15th, 2010, 09:19 AM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
seats
I considered a set but it sits too high in the seat (space between steering wheel). Also too tight between door cards and tuffty console. I wanted to stay with Land Rover heated seats, however, RR, Freelander (rails are wrong) seats, same problem. Being too cheap to buy customs, I scoured the junk yards for the lowest profile cushion sport seats...found Hyundai Tiburon sport seats for $100/set. Added seat heaters and could not be happier. They have plastic backs with net, blk/gry fabric matches the interior, the seat rails match, though I had to drill and remount two bolt holes in the seat boxes; are longer & bolstered for better thigh support; able to slide them farther back (more leg room) etc. I do cringe a bit knowing that I am sitting in non-OEM seats (my ass is very happy), however, the originals are proudly displayed on my shop wall…never to be sold!
Old October 15th, 2010, 09:46 AM
Paul, how about the height of the seat base compared to the stock seats? I am actually looking for a solution to lower my butt in my series so I can see through the windshield without hunching.
Old October 15th, 2010, 09:51 AM
PMKColorado
Paul Koentges
seats
I will measure and post a pic...
Slightly higher but I see fine…6’-0” average torso…
seat box to front cushion height = 6 1/2"; OEM seats at 5 3/4"; the Hyundai seat is lower than the OEM at the back of the seat and is manually adjustable.
If your "monkey torso" can't see out of OEM...you might have to look at sitting on a bleacher pad... , I don't think you will find a lower seat bottom.
ID:	32153   Click image for larger version
Old October 15th, 2010, 09:54 AM
I'm interested in seeing it, but don't got to any trouble over it. If it's higher I can't use it (6'-3" monkey torso)
Old October 15th, 2010, 10:57 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Is shortening the seat-box an option? The D1/D2 seats aren't much more comfortable than the Defender ones. I'm finding my biggest issue is the leg angles/room more than the seats themselves, I've got a set of Exmoor ones on the way and will be playing around with different spacers to try to get things comfortable and get rid of the horrible clutch knee pain.
Old October 15th, 2010, 11:05 AM
Paul you are likely right on the bleacher pad . The back portion of the seat is the part that needs to be lowest though. I am going to see if I can find some foam that can give adequate support without being too thick, but I think I'll need parabolics to help cushion the ride too
I have not measured, but my butt isn't too wide so a "scalloped" seatbox lid may be part of the solution, assuming I am not wider than the lid.
I'd like whatever changes I make be reversible, otherwise I'd do a bulkhead eliminator bar and mount a seat further back.
Sorry for the hijack Larry.
Old October 15th, 2010, 11:10 AM
ajh
Andrew J. Hutton
The half-inch neoprene foam I got from the Foam Factory to put on the bulkhead behind the dash makes a good seat base against the board, if you can work out the correct shape a firmer closed-cell foam will be a lot more comfortable. Perhaps we could convince Corbin to start doing Defender seats that don't cripple too.
Old October 15th, 2010, 11:17 AM
Ok, I went out and tested. The seatbox lid is substantially narrower than the rails and offset to the left so trying to have a lid that curves lower than the seatbox top surface isn't going to work.
It appears I need a max of 2" of cushion height (after compression) above the seatbox at the rear 1/3 of the seat to be able to see comfortably out the windshield. I'll look into foam options, but will try bleacher pads tomorrow
Old October 15th, 2010, 11:28 AM
PMKColorado
Paul Koentges
add a couple rolls of ducktape (seatbelts) and you are golden! Maybe you should chop the D-90 so you can see "over" the windscreen...
Old October 15th, 2010, 11:30 AM
draaronr's Avatar
draaronr
Here
LR3
I've done d2 power heated seats in a Defender and second row. Here are the pics, the whole front seat box is cut up and reworked, different more narrow center console, and customer wanted rear seats pushed back for more leg room so had to cut and modify the wheel wells. Coolest thing is the second row has the shoulder belt built into the seat for a true clean 3 point.
And BS d2 seats are way nicer than defender seats.
ID:	32155   Click image for larger version
ID:	32157   Click image for larger version
Old October 15th, 2010, 11:33 AM
Too funny. I don't have this problem in the Defender, just the series. Maybe a taller windshield for the summer, and the standard height when I put the hard top back on...but then the winter is still a hassle. Naah, I'm going to start hunching over eventually anyway as I get older
Old October 15th, 2010, 11:37 AM
PMKColorado
Paul Koentges
seat humor
sad that we are all so addicted to our LR’s…the things we are willing to overlook…too bad we can’t always look at life in the same way…enjoy. Larry…sorry for the highjack, good luck with seats.
seats, series
Conatiner Arrival means Defender / Series Parts Clean Out SafariHP The Vendors Loft 18 December 5th, 2008 09:38 AM
Defender or Series Fold Down Side Steps boshea For Sale - Parts 1 June 17th, 2005 03:57 PM
Wanted: Defender SEATS VinceatReal4x4s Wanted 1 February 6th, 2004 04:39 AM
Wanted 97 Defender Gray Jump Seats rbtrader Wanted 1 October 10th, 2003 10:29 PM
