D1 axles in older D90 - Page 3 - Defender Source
Old April 27th, 2013, 10:11 PM
jafir's Avatar
jafir
Jafir Elkurd
Low rider:
And finally disc brakes in the back!
Old April 27th, 2013, 10:14 PM
jafir's Avatar
jafir
Jafir Elkurd
I'd worry about the railco bushings/ swivels if those arms are bent. I have ruined a front axle housing and not bent radius arms like that.
Yeah those are rears and I have no idea how they got like that.... But now you've got me worried because one of the front radius arms on the new front housing is bent pretty badly. I'll look it over really well before I install it, though I'm not in too much of a hurry for the front. I really hate drum brakes.
Old April 27th, 2013, 10:45 PM
jafir's Avatar
jafir
Jafir Elkurd
So... who knows how shocks are measured? The terra firma catalog says the rear shocks I have got are 383mm closed, which is about 15.1 inches. When I sat the rear axle on the bump stops with no springs or shocks, I measured from the center on the top eye mount to the plate on the axle that the pin mounts to, and got 17.25" Assuming that terrafirma measures their shocks the same way I do, I should be good to install at least the rear shocks without worrying about bottoming out the shocks.... but is that how shocks are measured?
Old April 27th, 2013, 11:06 PM
It should be from the pin to the top of the bush. Made sure you check in articulation.
http://www.red90.ca/rovers/shockinfo.html
Old April 27th, 2013, 11:14 PM
I should know but I dont, what are the railco bushings?
Old April 28th, 2013, 12:13 AM
jafir's Avatar
jafir
Jafir Elkurd
I had to google it. It guess they are only on older style axles.
Part number 4.
Old May 11th, 2013, 02:23 PM
jafir's Avatar
jafir
Jafir Elkurd
Does a drum brake style rear axle have any value to anyone? I was thinking about pulling the diff, axle shafts, and drive flanges off of it and recycling the rest. I figure someone might need a 10 spline axle shaft so it might make good spares to take to a rally. I figure as much as this thing weighs, I might get 1/4 to half my money back just in scrap. But I don't want to do that if someone at some point might need it.
Old May 12th, 2013, 02:09 AM
Unless it has a 4pin diff, I am going with no.
Old May 12th, 2013, 04:01 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Those rear arms most probably got bent in a rear end shunt or rolling back hard into something immovable.
Yes you really need to check the shock lengths with the axle on full articulation, i.e chassis up on stout axle stands one side of the axle jacked up as high as it will go - on the bump stop and the other dropped as far as it will go. The length between shock mounts on the high side will be much shorter than measured with both sides sitting on the bump stops and correspondingly longer on the low side.
Mike Hammond
Old May 12th, 2013, 11:23 AM
jafir's Avatar
jafir
Jafir Elkurd
I figured it wasn't, but I thought I would check first before I send it away and then kick myself later.
------ Follow up post added May 12th, 2013 10:26 AM ------
Thanks. That's the plan. Right now I'm just running the stock shocks.
90, axle, d90
101 FC axles for sale Method PHX For Sale - Parts 18 March 24th, 2006 10:27 PM
95 D90! TwisteD90 For Sale - Vehicles 30 September 14th, 2005 02:54 AM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
1985 d90 PurpleHaze Defender Technical Discussions 5 May 4th, 2005 04:53 PM
