D-90 Door check or check rod question - Defender Source
Old November 28th, 2005, 08:37 PM
dfscott
Daryl Scott
1994 Defender
Can someone tell me where I might purchase a set of door checks or check rods for my front doors. I'm told these will keep my door from closing when it is open. Do these work well? Are they easy to install? Thanks. Daryl Scott
Old November 28th, 2005, 10:17 PM
You probably have a 94 if you have trouble with the door staying open - switch to 95 doors and catch and they'll stay open. I dont know of a remedy but maybe someone else has an idea.
Old November 28th, 2005, 10:28 PM
check the FAQ section a few pennies works well
Old November 28th, 2005, 11:27 PM
Mark M
Mark Mathews
'94 Beluga Black ST
If you have a '94 you are out of luck without either changing to '95 or '97 doors or fabricating a custom mount. The attachment point on the '94 doors is totaly different from the later models. If you search this forum you should find a prior post I made regarding the same issue. I still haven't decided what solution I am going to pursue, but I am REALLY tired of having the doors try to amputate my shins
Old November 29th, 2005, 07:00 AM
dfscott
Daryl Scott
1994 Defender
Mark: I saw your previous post and I also saw the penny remedy earlier. I thought your solution was for the 94 that's why I further inquired. Thanks for the clarification. I'll give the penny remedy a go. Any other ideas?. I recently installed stock door checks in my 80 Mercedes and what a difference. For some reason the door issue grates on me. Regards. Daryl
Old November 29th, 2005, 11:23 AM
dfscott
Daryl Scott
1994 Defender
I looked in the FAQ for the penny fix. I saw it somewhere yesterday with a picture, but my all to domed head isn't serving me well today. Where is it? Daryl
Old November 29th, 2005, 11:51 AM
http://www.defendersource.com/tech/penny.html
90, d-90, door
Check Engine light Question? True or False? Hammertime Defender Technical Discussions 0 April 5th, 2009 10:39 PM
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Panhard Rod Bushing Question JBurt Defender Technical Discussions 3 December 31st, 2004 08:45 PM
Question about selling dave_lucas Misc. Chit-Chat 8 January 2nd, 2004 08:34 PM
