D-90 A/C removal - Defender Source
Old January 11th, 2005, 04:24 PM
jim_harriger
Jim Harriger
1997 D90 S/W
D-90 A/C removal
My wife and I have a 1997 NAS D-90, which we have a great time with; nothing extreme, just exploring
the mountains around here and getting closer to the great scenery we have nearby.
We've noticed that we only use the A/C about once every 245 months, and we're getting tired of the space it takes up out of the interior. So we're thinking about removing it. Is this a feasible DIY project? is there
any market for the complete system after we've removed it?
opinions? gotchas we should watch out for?
thanks all!
Jim Harriger
Duvall, WA USA
Old January 11th, 2005, 05:03 PM
Theres a market all right, lots of folks will pay 1k or so for a working AC.
Removing it is simplicity itself, but you need to have the system discharged first by a technician at a dealer or AC place.
The only thing to really watch for is the fittings, especially the ones that enter the condensor which sits in front of the vehicles radiator. The thing is made of aluminum and the fittings are fragile.
There is also residual pressure left in the system even after its evacuated, so be careful while loosening the first fitting.
The parts of the system are as follows:
Underdash vent assembly
Underdash blower unit
Hoses
Compressor, on top of the motor
Condensor in front of radiator
Little canister under the PS resevoir
Wiring
Disconnect all the lines, finesse them out, and then just remove each piece individually. Too easy.
Old January 12th, 2005, 03:08 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Problem is you will have to leave the compressor in it to drive the serpintine belt.
JP
legend in my own mind
Old January 12th, 2005, 05:50 AM
So, all the 97s have a compressor even if they did not have AC
Old January 12th, 2005, 01:04 PM
pendy's Avatar
pendy
jim pendleton
89'd90
That is my understanding. Have not seen this yet, but crazy George confirmed it once.
JP
Old January 13th, 2005, 11:07 AM
GRRR! So now I need to get an AC compressor for my 4.0 so that I can get the belt on? I guess I can't just get a shorter belt? Anyone got a junk AC compressor for a 4.0 they want to get rid of cheap?
Old January 13th, 2005, 11:33 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
cant you just change the pully on the one you have mike
Old January 13th, 2005, 12:03 PM
Nope, they are different compressors from what I have seen.
Old January 18th, 2005, 10:02 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Land Rover built a 50th limited edition 4.0ltr ,a/c was optional there is a belt for it
part # ERR2678
needs to be orded from L/R UK
if Mike wants one i will be getting my friend to send one in the next few days
Old January 18th, 2005, 12:32 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Thats good information, thanks.
JP
Old February 4th, 2005, 04:55 PM
OK, I think I got this figure out but I am not sure everything is turning the right way. Can anyone confirm with this setup / belt config on a 97 that I have aeverything turning the right way? I know bad pic, but camera has a dead battery so i used a PDA. Thanks!
Old February 4th, 2005, 06:17 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Mike that might work but I am trying to get my scanner working & I will send you pic from my manual!!
Peter
Looks good but you might have to rotate your tensioner!
Old February 4th, 2005, 07:39 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
That is correct. My truck has no AC but still has the compressor. As it was told to me, All 97's left the factory with one and the AC was a dealer option. The port of entry for my truck was Toronto, and it was sold in Vancouver, without AC by the dealer.
EwS
Old February 4th, 2005, 08:13 PM
draaronr's Avatar
draaronr
Here
LR3
Jim do you want to sell it once you get it out, minus the compressor? If so drop me a pm I am interested.
Old February 4th, 2005, 09:09 PM
PERFACT! Thanks Peter! I'll have to look at rotating the pulley; I may just leave it as everything is going the right way.
Old February 5th, 2005, 12:02 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
You have a lotta 90 degree turns & belt life & bearing life my be compromised BUT if it works don't fix it!
Old February 5th, 2005, 10:35 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Aaron,
I've got AC and never use it, been thinking about taking it out after this topic. I'm pretty uncomfortable taking it out though, but if I rip it out I'll let you know.
"It's not a Jeep"
Old December 17th, 2006, 11:51 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Hoses
Wiring
I am planning on removing the A/C system from my 95 Defender to add more room to the footwells. Is it safe to remove the compressor and use a shorter surpentine belt? Or should I just leave it in and disconnect the connections?
Thanks for the help!
Greg
Old December 17th, 2006, 12:28 PM
Andrew Vick
Andrew Vick
95 D90
If you have a 95 as in your profile, you don't have a serp belt. You can remove the compressor and the belt that drives it.
Old December 17th, 2006, 12:44 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Excellent, thanks for the help!
Greg
90, d-90
1994 Defender 90 - Hardtop and A/C silver_defender For Sale - Vehicles 4 August 14th, 2009 03:31 PM
90 ST Cage Removal bjf Defender Technical Discussions 9 August 6th, 2009 04:09 PM
A/C removal from a 1994 paulb Defender Technical Discussions 0 September 17th, 2007 11:32 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
94' Defender 90 A/C unit RX6RCROL For Sale - Parts 6 March 19th, 2004 08:41 PM
