D-90 1995. Front axle question. - Defender Source
Old September 17th, 2010, 07:38 PM
triathlon616
sage mount
1995 defender 90
I have my eye on a 1995 d-90. It was stolen and stripped of the front axle housing, radiator, all lights, all tires, windows broken out etc. She has 129000 mi on her. Body looks clean salvage value anybody? If I buy ill need an axle housing. What rig should i scavenge from Discovery? What yr? and should i buy both the front and rear axle housing's? what would you guys do? Thanks a million.
Old September 17th, 2010, 11:30 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
1994-1999 D1 or 1994/95 RRC. in both cases you will need to change the front rotor's and calipers to d90 spec. the reat is the same.
Keith
Big, Red and ... aaa Red..
Old September 18th, 2010, 11:39 AM
triathlon616
sage mount
1995 defender 90
Thanks for the info helps alot. As the truck is on its frame rails in front ill need to find springs and stabilizer arms for axle will the disco parts work? The d90 needs a complete front axle, track bars, springs, brakes, pitman arm drive line etc can i rob all these from the disco?
Old September 18th, 2010, 11:57 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Yes, with exception of the drag link and the pitman arm everything is the same.
Keith
Old September 18th, 2010, 11:58 AM
triathlon616
sage mount
1995 defender 90
Thumbs up
Awesome that really helps me out. Have a great weekend.
Old September 18th, 2010, 08:19 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Why do you need to change the rotors and calipers? I swapped a disco axle in the rear and used the calipers and rotors.
Old September 18th, 2010, 09:48 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
The front calipers and rotors are smaller on a D1 then they are on a d90. The rear is the same on both cars.
Keith
Old September 19th, 2010, 01:27 PM
triathlon616
sage mount
1995 defender 90
Question
How hard will it be for me to find d90 calipers? Could i use the disco brake system until i find the d90 parts or would it be unsafe 2ndry to?
Old September 19th, 2010, 01:45 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Justin at Lucky 8 can get them for you, or even the local auto parts store might be worth a try, I'll bet Justin's prices are better though. The Dsco calipers are just smaller diameter pistons, they will work just not as well.
I've even toyed with the idea of using a disco pitman arm on my Defenders simple because the setup is stronger, the drop is not as much on the Disco arm though so that will lead to more angle on the drag link leading to more bump steer. The benefit is loosing the silly joint on the Defender pitman arm in place becomes a simple tie rod end.
Keith
Old September 19th, 2010, 10:39 PM
triathlon616
sage mount
1995 defender 90
I appreciate all your help. Your all a wealth of info cheers.
1995, 90, 95, axle, d-90, front axle
1995 Defender 90 ST - AA Yellow AggieD90 For Sale - Vehicles 7 February 14th, 2009 11:01 AM
1995 D-90 for sale Peter For Sale - Vehicles 6 December 24th, 2004 01:00 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
