D-110 Oil Light Flickering?? - Defender Source
Old May 25th, 2004, 06:42 PM
sharknet
frank berry
Defender 90 1994
D-110 Oil Light Flickering at Idle??
We recently replaced the ignition module on my 110 and now the oil light is flickering at idle- once you accelerate it goes away - doesn't appear to be losing any oil - pressure seems ok- temp is good - any help would be appreciated - thanks fb
fb
Old May 25th, 2004, 10:04 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
FB,
If the gauge pressure is good, I'd replace the sending unit for the light. They can fail at higher mileages. The new parts are of an updated design. Last time I bought one they were about $10 at the dealer.
RD
Old May 26th, 2004, 08:52 AM
Frank, my light starts to flicker when I need an oil change, honestly when I get near 3k the light flickers and after I change the oil it stops.
Old May 26th, 2004, 09:11 AM
sharknet
frank berry
Defender 90 1994
thanks guys - i'll start with an oil change to 20/50 - that was recommended for a high mileage (120K) engine in the summer - then go from there - fb
fb
Old May 26th, 2004, 11:06 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I had the same problem a year ago!!! It is the sending unit!!! Don't worry!
Peter
Old May 26th, 2004, 12:19 PM
Hibbert,
That is a sign of a leaky injector. Does the oil smell like gas?
Ron
Old May 26th, 2004, 12:23 PM
Hmmm I don't rember it smelling like gas, what else would I look for if I had a leaky injector?
Old May 26th, 2004, 01:29 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
A non symetrical looking spark plug.
Old May 26th, 2004, 01:45 PM
So I need to pull your plugs and check em.
Old May 26th, 2004, 01:48 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
no you need to pull your plugs and check em! I think that is the best way I could be wrong! Short of pulling your injectors & bench testing.
Old May 26th, 2004, 01:59 PM
OK I'll pull my own pulgs . And I hope it's the best way as I don't have a bench to test my injectors on.
Old May 27th, 2004, 09:57 AM
Either that or you have an oil leak and it take 3000 miles for it to get low (but I figured you checked oil level frequently enough).
Ron
Old May 27th, 2004, 10:06 AM
Ron, you must have been reading my mind. It does eat/drip oil a little and i have noticed it takes about 3k to get down 1/2 a quart. Sometimes it goes faster if I do more highway driving. As soon as the light comes on I change the oil, one it normally takes about 4 months or 3k miles, and 2 I like to play it safe.
110, d-110, ht
110 Oil Light and temp gauge bjf Defender Technical Discussions 25 May 26th, 2009 09:45 PM
Oil Light Flickering/Oil Pump Glenn_Guinto Defender Technical Discussions 13 October 27th, 2004 08:27 AM
