Cylinder heads - Defender Source
Old February 4th, 2009, 07:49 PM
61rover's Avatar
61rover
John Crouse
Cylinder heads
Are the heads on a '97 disco the same as those on a '94 Defender?
Old February 4th, 2009, 10:47 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Nope. Less head bolts on a '97 head than on a '94.
My oil line fix
My 100k stopped odometer fix
Old February 5th, 2009, 08:16 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
They do fit if you use the new style head gaskets and new bolts.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old February 5th, 2009, 08:43 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
After doing heads on the 3.9 and the 4.0 I would keep the old style head and bolts over the stretch bolts. I hate those things. I know the theory but I am much more confident that i have torqued everything on the old style than the new style. I followed the book on the stretch bolts and had the heads done by the machine shop but it seemed to me that some bolts were harder to turn those additional degrees than others. just didn't sit well with me.
Old February 5th, 2009, 03:03 PM
"They do fit if you use the new style head gaskets and new bolts."
Yes, and if you use the old heads with the new gaskets, your compression ratio will be lower due to the thickness difference of the gaskets.
Old February 5th, 2009, 08:07 PM
AggieD90's Avatar
AggieD90
Kevin Collins
'95 AA Yellow & '97 Willow Green
Unless your heads are out of spec a machine shop should not charge much to do a valve job on them and shave off the minimum to put them back on. I just had mine done (went back in the truck today). Total was just over $300.
Old February 6th, 2009, 08:51 AM
LRover's Avatar
LRover
J. Michael McCaig
I purposely used the new style gaskets with old syle (87) heads when I built my 4.6 to lower the compression ratiio so I could run regular gas. Its worked well. Oh and I used the old style head bolts too.
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Wolf XD mirror heads - anyone using these? solihul Defender Technical Discussions 8 May 18th, 2005 01:03 AM
Redo heads or not? mlw911 Defender Technical Discussions 14 October 21st, 2004 02:42 PM
What do I need to know about rebuilt cylinder heads (non-LR) loykd Defender Technical Discussions 2 October 18th, 2004 10:36 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
