Cylinder Head Studs - Defender Source
Old July 23rd, 2014, 12:31 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Cylinder Head Studs
Okay, I looked, I really did.
Turner 4.6 just off the aero-plane
Freshened heads from Wichita
Composite gaskets from Indiana
The box-o-studs just arrived from Summit.
I'm reading the instructions ... I know, that's my first mistake...
This is indeed the ARP #157-4301 that's just ten per side, not fourteen.
Here's what I'm concerned with...
The ARP instructions spec 100 lb/ft as a final torque having been snuck up on three times.
I dunno, but 100 lb/ft sounds like a pretty big number to me.
Thoughts???
Old July 23rd, 2014, 12:45 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
You'll pull the studs out of the block before you hit 100 lb/ft. I'd go about 65lb ft. I used stude for a short while and have since switched back to factory bolts.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old July 23rd, 2014, 12:46 PM
Make sure you use the ARB lube. 100 lb-ft is less than you would put in the stock stretch bolts. It does not sound high to me.
Old July 23rd, 2014, 12:51 PM
UnfrozenCaveman
Keith Armstrong
Various
Thanks Rob.
I've got the lube...I was thinking 60 - 70 somewhere...
I've got new bolts too...really...you're back to the bolts?
Word on Noah's LWB
Old July 23rd, 2014, 01:02 PM
M.A.R.S.
Drew
R.R. classic
x2 on bolts. I have used the studs before as well and like the factory bolts better. The old steel head gaskets head bolt torque is 66 lb/ft.
Old July 23rd, 2014, 01:47 PM
Roadsiderob
Robert Dassler
1994 D90
Keith,
I've pulled threads out before I hit 80. I wouldn't go more than 65. You have to keep in mind that you will be torquing a well lubed fastener that has fine threads....the block end has less engagement than the factory bolts and is coarse threaded. The strength of the fastener is not the issue, it's the strength of the threads in the block and the engagement depth. I got the 65 ft/lb spec from the guys at Aluminumv8.com.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old July 23rd, 2014, 02:00 PM
I went 70ish in a few sequences
Old July 23rd, 2014, 02:12 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
1st. Snug (or 25 for rookies)
2nd. 55
3rd. 70
You can go to 75ish by feel if needed.
------ Follow up post added July 23rd, 2014 02:15 PM ------
Here da cheet sheet. Been used hundreds of times. Print it out and lay it on the valley, its good luck. Never had a single problem using lightly oiled factory type TTY bolts.
Old July 23rd, 2014, 02:24 PM
UnfrozenCaveman
Keith Armstrong
Various
Originally Posted by Roadsiderob View Post
...the block end has less engagement than the factory bolts...
wait...really??
Crikey, that's silly.
I'll have a look at the engagement before I do anything.
Probably be just as silly to cut more threads in the studs.
Sheesh, I may be looking for a solution to a non-problem, eh?
Old July 23rd, 2014, 02:40 PM
crown14's Avatar
crown14
Verticalscrote
Originally Posted by UnfrozenCaveman View Post
wait...really??
I hear a lot of guys running studs complaining because they have to go back and re torque.
Old July 23rd, 2014, 04:07 PM
technically speaking there should be no reason why studs would have to be retorqued...
Td5 cylinder head new pendy For Sale - Parts 4 March 31st, 2012 11:45 AM
Head Studs--torque sequence Davis Defender Technical Discussions 2 January 19th, 2010 01:22 AM
200 tdi cylinder head? Hoosier Defender Technical Discussions 10 July 7th, 2009 07:29 PM
Cylinder head bosch with seconday air budz For Sale - Parts 2 June 23rd, 2009 04:31 AM
Southwest Rovers Cylinder Head chris snell Misc. Chit-Chat 1 August 21st, 2007 10:31 AM
