Cyl 5 Misfire - Defender Source
Old January 6th, 2012, 10:24 PM
Mpower619
Ricardo Gomez
1997 D90
Cyl 5 Misfire
Newbie here! Anyone know how to repair a cylinder 5 misfire? Trying to smog my car bbut have a check engine light on. Already replaced all O2 sensors and Temp Switch and now have a cylinder 5 misfire fault code. All help is appreciated.
Old January 6th, 2012, 10:58 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Details would help. Vehicle model, engine type, etc
Old January 7th, 2012, 04:36 PM
Mpower619
Ricardo Gomez
1997 D90
ha, sorry about that. its a 1997 D-90 4.0
Old January 7th, 2012, 08:30 PM
coil pack? I dont think these ever go bad. WHat fuel what plugs and what mileage?
Old January 7th, 2012, 09:27 PM
I can not confirm this but, I have been told this before, check your ABS sensors, I have heard that when they are bad, caked with mud or misaligned they can produce misfire type information? Can someone confirm this?
The truck does not have ABS, but it does have the sensors and they are tied to a rough road sensor?
Old January 7th, 2012, 09:46 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
How are the wires in this thing? You might start by buying a set of genuine wires and see if your problem resolves itself. Is the misfire continuous? Does it happen at a certain engine speed? I have seen a couple trucks with faulty vehicle speed sensors misfire too. If you can look at the freeze frame data, check to see if it says the truck was going 28,000 mph or something when the fault happened. Hopefully it isn't a sticky valve, which can only be remedied by pulling the heads.
Old January 7th, 2012, 11:10 PM
Mpower619
Ricardo Gomez
1997 D90
Thanks guys, im going to start by buying new plugs and wires. Then Ill scan it again.
fire, misfire
Misfire / Very poor fuel economy Jerry Defender Technical Discussions 14 November 13th, 2017 10:24 PM
Cylinder 7 misfire aosias Defender Technical Discussions 5 July 25th, 2010 11:30 AM
ignition/engine misfire code (sleuth work needed) hlamar Defender Technical Discussions 7 July 19th, 2010 08:06 AM
misfire dosepe Defender Technical Discussions 2 April 18th, 2007 08:50 AM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 10:30 PM
